Author Topic: Dyson - DC41 - Fusing at main fuse box  (Read 549 times)
Offline Chris Mc
« on: July 27, 2019, 11:47:52 PM »
Hi
My DC41 clicks for a second when I turn it on then and blows fuse in main fuse box.
Any clues ?
Online ryevac
Re: Dyson - DC41 - Fusing at main fuse box
« Reply #1 on: July 28, 2019, 02:08:57 PM »
Short circuit on cable
or
short circuit around switch area internal
more likely pcb fault in ball assembly or the main motor itself.
Try turning off head motor next to main switch, then power up. If it doesn't trip then it's the head drive pcb - if it still trips then it's probably main motor, If motor bearings seize then that can cause this.
If you are not confident in tracing this type of fault then it needs to go to a competent repairer.
