Ok has anyone ever tried and successfully fitted a Non Miele motor in to a Miele Vac.
I have been experimenting out of interest by fitting Dyson DC08 DC25 and DC40 motors and others of similar make up and varying wattage's.
I have used the small Pcb from inside the original Miele motor and fitted it in with the replacement motor so that the speed control works.
I have tried it with original Miele Toc and donor motors own Toc.
Every motor I have tried always over heats and stops.
I've tried 850wat motors same happens.
Now your basic Dyson motor is fitted in a small tight fitting pot where the Miele machines have a larger area for hot exhaust to circulate and exhaust out.
Anyone have any ideas why this happens ?
I thought it was wattage but ive tried 1600w Motor in a 300 to 2200wat Miele machine same happens
