Author Topic: Sebo Airbelt E1  (Read 3670 times)
Online Halcyon
Re: Sebo Airbelt E1
« Reply #15 on: January 06, 2020, 08:45:15 PM »
Is there anything I can do? Seals are clean, nothing's broken
Re: Sebo Airbelt E1
« Reply #16 on: January 07, 2020, 04:07:11 PM »
If its not obvious to you after inspecting it, its a job for your local competent repair shop.
Online Halcyon
Re: Sebo Airbelt E1
« Reply #17 on: January 07, 2020, 07:01:35 PM »
Well, nothing's obvious to me anymore as I've sent the video to SEBO and in reply I got that apparently it's normal.
Online Halcyon
Re: Sebo Airbelt E1
« Reply #18 on: July 19, 2020, 12:19:47 AM »
I got this Boost model at reduced price so sold the white one. It's got more suction and came with this head  that is soo much better than Kombi head. Not sure why it isn't included as standard..
Like I mentioned before, SEBO has got some issues with really loose connections at joints. I can literally hear the air leaking when I push the head on carpets.. It just doesn't fit the wand very good.
He mentions this problem too. Sadly it is happening with new machines as well. I've also tried K1 in John Lewis' and it was the same. Not to mention that on K1 the air is leaking where the exhaust filter is, under the filter cover.
Even the wand doesn't feel as sturdy as Miele's.
Guess I'm not the only one making spurious claims..
I've used many vacuums and I must say I think E1's the one I enjoy using the most. Nice and easy to use, light, quiet and has onboard tools. It's such a shame that they didn't make the connections much tighter. I'm pretty sure it has some influence on the performance. Unless they've done it on purpose. Anyway, it really annoys me when I hear that hissing air.
Need to say that your adapters are incredible! Good job!
Re: Sebo Airbelt E1
« Reply #19 on: July 19, 2020, 10:38:48 AM »
Glad you like the adaptors.  :thumbsup:
Great last shot too.
That black E1 is the latest one with those heads, they are the newest types.
Re: Sebo Airbelt E1
« Reply #20 on: July 19, 2020, 07:57:16 PM »
Those adapters are good aren't they! Bet that sebo spins the turbo head up a treat on full power!
Online Halcyon
Re: Sebo Airbelt E1
« Reply #21 on: July 19, 2020, 09:45:56 PM »
Yes, it does work really good!
Like I said though, the connection between wand and head isn't very tight so it doesn't give its best I think.
I've had two second hand Mieles and their connections were really strong even though parts were worn. I couldn't hear any air leaking anywhere on them.
I must say as well, Sebo's version of this head has a vent on the top that easily opens. It can be a bit annoying when you vacuum under some furniture and you accidentally open the vent while pulling the head backwards.
Miele's Turboteq is better cause you need to twist it to open the vent.
Online Halcyon
Re: Sebo Airbelt E1
« Reply #22 on: July 21, 2020, 02:58:58 PM »
It's really noticible with Kombi head. The wand literally slightly twists left and right even clicked into the head.
It's the same at the joint where hose connects with the wand.
Online Halcyon
Re: Sebo Airbelt E1
« Reply #23 on: July 28, 2020, 10:24:44 PM »
I know most people don't really care about these things, but I'm a little bit OCD.
I've also noticed that the dust must be leaking around here. I've cleaned it many times, put a little bit of vaseline like SEBO told me to but it just  gets dirty around there after few uses anyway.
