Author Topic: Sebo height adjustment  (Read 3544 times)
Offline Plin1946
« on: June 19, 2020, 05:56:26 pm »
Firstly, thanks to Tonsberg for a superb post, which gave me the courage to have a go at fixing the height adjustment gadget on my Sebo X4.  Now, three questions please -
What, should the full range of lift be, in mm, at the front of the machine - I got mine working, but the full movement doesn't seem to be all that great.
I suspect the brush is significantly worn - what should the bristle length be (eg as new)
Finally, I was unable to remove the upper casing of my Sebo - I undid the three main screws, but it appeared still to be held on.  What did I miss ?
Many thanks to anyone who has read this far and, especially if they can advise.
Re: Sebo height adjustment
« Reply #1 on: June 21, 2020, 04:09:16 pm »
It's not always about the height of the brushes, it can be their stiffness.
If your brushroll is of an unknown age, or has white bristles, change it as a routine matter. That solves the vast majority of automatic height adjustment issues.
The lift is variable depending on what surface its on. As for getting the top off, Beko has done a strip down topic in the stickies.
Offline Plin1946
« Reply #2 on: June 22, 2020, 09:13:30 am »
Thanks MVacs, mine has white bristles .... order is on the way for a new brushroll !
Offline Plin1946
« Reply #3 on: June 23, 2020, 11:29:17 am »
Hello MVacs.  Thanks for new brushroll - certainly has increased range of auto height adjustment and reduced rolling resistance on deeper carpets.  I'm now curious about the bearing in the brushroll end cap.  If I insert a metal rod into it (where the brush shapt goes), it has some radial movement from side to side - eg like a car suspension ball joint - but it shows no interest in rotating.  It looks as if there should be a ball race in there - is there ?  - or is 'bearing' for the brushroll between the brushroll shaft and the metal inner tube of the part pressed into the end cap ?  Seems a bit inlikely.
« Reply #4 on: June 24, 2020, 07:43:32 am »
I'm now curious about the bearing in the brushroll end cap.  If I insert a metal rod into it (where the brush shaft goes), it has some radial movement from side to side - eg like a car suspension ball joint - but it shows no interest in rotating.  It looks as if there should be a ball race in there - is there ?
No ball race, that's correct as you describe. They dont have a traditional bearing.
Offline Plin1946
« Reply #5 on: June 25, 2020, 09:07:24 am »
Thanks.  That's quite surprising.  Should it be oiled / greased regularly ?
« Reply #6 on: June 25, 2020, 05:17:43 pm »
Surprisingly not. If you do they often gum up. You can put a tiny bit of white silicone high temperature grease in if you want. Normal grease/WD40 etc will gum it up. Using nothing is fine. Strange but true.
Offline Plin1946
« Reply #7 on: June 26, 2020, 08:34:54 am »
OK, very many thanks.  Great service Manchester Vacs !!  :tiphat:
« Reply #8 on: July 19, 2020, 06:26:40 pm »
As an update to this subject, and for the benefit of passing readers, I've just done a blog post on this very subject here: Is Your Sebo Automatic X Vacuum Hard to Push? How to Fix It
