Author Topic: DC39 Top Duct Assembly  (Read 624 times)
Offline lindaekes
« on: July 17, 2020, 04:24:06 PM »
I need to replace the top duct assembly on my DC39 - I don't want to disassemble the whole thing if it can be done more simply.  Any Advise?
Offline bluebumble485
Re: DC39 Top Duct Assembly
« Reply #1 on: July 18, 2020, 10:44:56 AM »
what do you mean  post picture please
Offline lindaekes
« Reply #2 on: July 18, 2020, 08:56:54 PM »
the part that holds it on broke off so the assembly just fell off.
i donít want to disassemble the whole thing if i donít have to to replace it
Offline lindaekes
« Reply #3 on: July 18, 2020, 09:04:03 PM »
trying for better picture
« Reply #4 on: July 18, 2020, 09:17:30 PM »
i see now i call that bit handle lol ,still i know now ,i tried to fit without taking to bits for a hour gave up ,next day took top part off where buttons area easy to fit then maybe someone knows a short cut i could not do it
Offline lindaekes
« Reply #5 on: July 19, 2020, 01:17:11 AM »
I am to where the hepa filter attached to lid and the white clips will not give at all to release - any help would be appreciated
« Reply #6 on: July 19, 2020, 09:37:34 AM »
been a while since i have done one ,press white lugs in with screwdriver it comes loose ,keep at it it will come off
Offline lindaekes
« Reply #7 on: July 19, 2020, 07:33:02 PM »
the only thing harder than getting the white tabs to let go is getting them to lock again.  any suggestions?
« Reply #8 on: July 19, 2020, 07:55:46 PM »
I use a small flat blade screwdriver, and at the front of the tans, push the driver between the housing and tab, then lever up under the tab, which usually brings the motor housing up and snaps it in. Can be a sod though, and make double sure the pedals are where they should be and no springs have fallen off before you do it...
