Author Topic: Dyson V6 - Stripdown & Refurb!  (Read 18552 times)
Re: Dyson V6 - Stripdown & Refurb!
« Reply #15 on: October 30, 2020, 07:16:25 pm »
This slides down into the cone assembly
Red gasket goes on now
Then sandwich it all together
Now, put this all in the top shell and fit the screws holding this part in
Then fit the inner black part, pushing it fully home
Then fit and screw the outer cyclone part down
Clip the shroud back on
Then fit the bin seal
Then snap the whole thing onto the motor housing
« Reply #16 on: October 30, 2020, 07:17:05 pm »
Next is the tool entry port.
Refitting the seal
Seems the flap just pops out, I'm refitting it so must have removed it!
Push the loom through from the front
Then wrap the loom around the bin, fitting the contacts
Then snap the cover on. Route all the cables
Then hope to heck everything lines up and the front snaps onto the bin...
Then push the connector in
ila_rendered.
Rubber up the bin flap
« Reply #17 on: October 30, 2020, 07:25:16 pm »
The bin flap can now snap on
And be fitted to the machine. Filter next
Which came up very well as they usually do
Drop it in
And one rebuilt Dyson V6
Rebuild whatever you stripped from the dock
« Reply #18 on: October 30, 2020, 07:30:41 pm »
Check it all still works
And these very photos sold it for £120 (back in 2018...)
Throughout all of this you may have noticed the lack of wand. Fully sealed up, I've tried and failed/given up before. Wipe down externally is all it needs.
Also, the above is a full stripdown. For a general refurb, unclip the cyclone assembly from the motor housing and just strip that and the floor head. Wipe down everything else and leave it whole, unless you've got a reason to be in there...
Hope this helps someone! Being such a common machine hopefully people will chip in with alternate ways of doing things, as everyone will have their process. I have mine now!
Offline Kerry78
« Reply #19 on: January 16, 2021, 03:21:23 am »
Well done ... I got one for £30 didn’t come with anything but it’s it’s good nick
With a few scratches to the wand cyclones filthy so I had to get a tool to take it off
As I did try and wash it under tap but no good 😂
