Author Topic: DC07 Roller Brush - Bristle Length  (Read 4506 times)
Offline methuselah969
  • Country: au
« on: February 12, 2021, 01:13:02 am »
I have just finished completely cleaning the Cyclone and everything else on my 17 Year Old DC07. The roller brush looks ok, but just wondering if anyone knows the length of the bristles?
Many thanks & greetings from Australia
Offline bluebumble485
Re: DC07 Roller Brush - Bristle Length
« Reply #1 on: February 12, 2021, 12:19:31 pm »
no idea just lube it up and try if it picks up ok you will know its all ok
« Reply #2 on: February 12, 2021, 02:23:40 pm »
There was a thread on this subject somewhere....
They are pretty indestructable i think, unless it has been used over stone floors and makes little difference if they are a little worn.
The actual length from new i thought was around 6-7mm ?
Never had one wear out, only replaced due to being cut through due to carpet thread or the bearing seized, causing massive heat build up damaging the bar.
