Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
News:
With photos. Find it
>here<
Click
>here<
Home
Help
Login
Register
Vax Vacuum Cleaners
Vax Air Cordless Duo - Stripdown & Refurbishment!
« previous
next »
Print
Pages: [
1
2
Go Down
Author
Topic: Vax Air Cordless Duo - Stripdown & Refurbishment! (Read 9344 times)
beko1987
Member
Country:
Gender:
Let's take it apart!
on:
March 18, 2021, 08:15:15 pm »
Tweet
A fair while ago now, I had 2 vax Air Cordless Duos in quick succession. One given to me by a fellow collector
//www.youtube.com/watch?v=133pWP_IUUM
and one a job, being TOTALLY dead
//www.youtube.com/watch?v=mw-CpZAMlq8
Between the knowledge gained from the dead one and the nothing to loose aspect of the 2nd, we find ourselves tearing it apart as usual!
I had this screw out at the top of the wand
But couldn't separate the two parts, so left it be.
Take the motor and bin off
To give it it's full title:
The hose comes off the chassis with 2 screws
Then splits down further still
At the top of the main chassis we see the adjusting handle lock
This just pops off, with it's flat spring
Logged
beko1987
Member
Country:
Gender:
Re: Vax Air Cordless Duo - Stripdown & Refurbishment!
Reply #1 on:
March 18, 2021, 08:21:45 pm »
The top cover around the switch housing pops up too
And lifts off
All the buttons and springs can be lifted out now
And we can see the 2 screws hidden under said switch housing
We can undo all of those and remove the cover from the spine
Noting how the wires run
Then pulling them all out, switches and contact plate as well
With a screw down the bottom
The other half of the main spine can come off, revealing, bizarrely a tissue...
Logged
beko1987
Member
Country:
Gender:
Reply #2 on:
March 18, 2021, 08:26:43 pm »
Like a real actual tissue!
We can now see where the spinal wires enter the machine base
The hose holders can get out of the way
This next bit was quite tricky due to how it clips together, but remove the long screw and washer holding the main pivot together
Then with the screws removed eventually it comes away and separates, showing the PCB controlling it all
I snipped the wires
Which enables the 2 halves to be separated (you could just de-solder the wires from the board but I'm always worries about ruining cheap board traces...). The plastic has some mega heavy metallic flake in BTW
Time to empty this part. Undo the screws holding the PCB in
Under the PCB sits the trim part for the contacts
Logged
beko1987
Member
Country:
Gender:
Reply #3 on:
March 18, 2021, 08:31:23 pm »
Once the wire clamps are removed and the board is out of the way, 2 screws allow the LED cover to slide off
Big old board for 2 LED's!
2 more wires to snip
This next bit was HARD, I think they push the centre bolt through the plastic with a machine, it was MEGA tight, you can see where I was leaning on it with a small pry bar...
Stupid bolt fell out the other side once removed though
Onto the bit that ALWAYS breaks now, the head! If your head is cracked and not fully destroyed, go buy some epoxy and get it stripped and repaired!
Baseplate off
Brushroll out
Logged
beko1987
Member
Country:
Gender:
Reply #4 on:
March 18, 2021, 08:35:12 pm »
Brushroll endcaps come off
Well, one does. The other, being Vax snaps off... Brushroll is a write off!
Grumble grumble move on...
This random red bit unscrews now
Then this clear cover over the suction duct
With a couple more screws the top cover comes fully off the head
The bit that makes it stand up straight snaps off easily
And it looks alot emptier now!
Belt ID incase it helps anyone. Good luck finding one...
Logged
beko1987
Member
Country:
Gender:
Reply #5 on:
March 18, 2021, 08:38:40 pm »
The other end of the curly cable can be unscrewed now
And the yolk and wire fully removed at last
Leaving this to lift out as one
Ickle motor, probably still more powerful than the one running a gtech air ram
Ah the fatal wheels! Assuming your bottom chassis is in tact, a circlip on either side removes the wheel axles
The nice front wheels come out too
And that's the head done! Motor/Bin now.
Motor first
Logged
beko1987
Member
Country:
Gender:
Reply #6 on:
March 18, 2021, 08:44:21 pm »
The previously washed and spotless filter shows the major drawback to this otherwise pretty decent machine, the cyclone is f :censored:g rubbish
Peel the VAX off
And find the secret screw.
The other one is round the back
And we can see the fiery heart of the dragon...
Here is the power switch board
Comes off nicely
Could not split this handle either so together it stayed
Time to remove the screws holding this together
Logged
beko1987
Member
Country:
Gender:
Reply #7 on:
March 18, 2021, 08:47:19 pm »
There is alot of dead space being filled in here...
The motor sits under various seals
And the fancase looks encouraging
But sadly this is as far as it goes
Motor control board sits here
Until it doesn't
And we can start on the bin!
3 screws hold these bits together
Logged
beko1987
Member
Country:
Gender:
Reply #8 on:
March 18, 2021, 08:50:18 pm »
That lifts off to reveal the small cone
Rubber seal here is quite critical, don't tear or loose it!
These screws separate the shroud and cone from the top housing
And also the shroud from the single cyclone cone
The bin flap pops off the bin
Then the seal comes off the flap
Logged
beko1987
Member
Country:
Gender:
Reply #9 on:
March 18, 2021, 08:53:51 pm »
Finally the bin flap latch pops off
The often ignored instructions! It's just simpler with a bagged machine...
And we are fully apart!
Everything was then washed, polished and dried
And we can start by refitting the bin flap latch back to the cleaner bin
Sparkly
Refit the flap seal
Logged
beko1987
Member
Country:
Gender:
Reply #10 on:
March 18, 2021, 08:56:58 pm »
Then take a good hard hold of your loose flap
And snap it back onto the bin (what else?
One clean cyclone cone
Plus some other cleaned parts
Rubber gasket goes on the top
Then the filter holder and shroud slide on either side
With the screws in you can let go and refit the very bottom seal to the very bottom of the cone. Make sure its fitted properly or it'll let even more dust through than it's designed to...
Then
Refit!
Logged
beko1987
Member
Country:
Gender:
Reply #11 on:
March 18, 2021, 08:59:56 pm »
With the bin done, it's time to fit the battery contacts trim part inside the motor housing
Then I built the motor back up
Which didn't take long
The assembly can be slid into one side of the housing
Then the other side
Topped off by the cap
Motor unit done!
And waiting at the side for the rest to catch up
Logged
beko1987
Member
Country:
Gender:
Reply #12 on:
March 18, 2021, 09:03:41 pm »
Which it quickly is doing as we refit the front wheels to the floor head
Wheels back on
Which makes it mobile again (so many got written off and scrapped for the want of this exact part in this state to be sold)
Feed the wire through the yolk and pop it on, and start to drop the electrics back in
Join the wires together. I soldered them, you can crimp them, it's not high voltage here.... I'd put the join somewhere else though in future...
Air path cover can go back on now
Then the top cover can be screwed on
Logged
beko1987
Member
Country:
Gender:
Reply #13 on:
March 18, 2021, 09:07:58 pm »
The red firewall can go in now
Then the baseplate (whilst we wait for a new brushroll...
The fake motor housing connected up to the yolk much easier than being removed (with a helpful hard smack from a hammer...)
Electronics back together
This was so long ago I was still trying to use my Dremel Versatip! It's awful for proper soldering (I've upgraded to an electric station now) although for melting heatshrink or using outside on the car it's pretty good.)
Feed the spinal cable through the hole in the housing first...
Then do the cover up and refit the hose holders
Run the rest of the wiring home
Logged
beko1987
Member
Country:
Gender:
Reply #14 on:
March 18, 2021, 09:11:16 pm »
Screw the cover back on
Refit all the switches and latches
And covers
And locking brackets
The wand can go in
Reassemble the hose
And it's done!
Eventually the new brushroll arrived and I could film an after video
//www.youtube.com/watch?v=5ejcXY4N38w
Logged
Print
Pages: [
1
2
Go Up
« previous
next »
Vax Vacuum Cleaners
