Author Topic: Dyson DC54 Cinetic Cylinder - FULL Stripdown and Refurb Guide  (Read 7105 times)
Re: Dyson DC54 Cinetic Cylinder - FULL Stripdown and Refurb Guide
« Reply #15 on: April 21, 2021, 09:45:53 pm »
Moving onto the lower layer now, fit the gasket to the underside
Gather up the sharp things
And fit them all back in
Drop the outer ring on
And fit
Back upside down and fit the last layer of rubber nipples
Then the bottom cone
Which I found would not go on with the cones fitted to the main unit. So i fitted the cones to the cone
Then sat it down and screwed it together
« Reply #16 on: April 21, 2021, 09:49:58 pm »
Looking better now
Very gently slide the shroud on and click it into place
Demonstrating the shroud cleaner. Made because you cant get even your little finger up here without removing the bin. I bet these never got used ever...
Rubber your flap up
And refit it to the bin. Fit the bin to the cyclone and THANK GOODNESS THATS OVER! The airflow will return once we make the sucky machine work... So. Seal onto the cyclone lock arm
And the spring
Clip it back onto the pivots but leave the tabs out for now
« Reply #17 on: April 21, 2021, 09:54:59 pm »
Motor time now. Plug it in and sit it in the housing squarely, then fit the rubber bushings
The sound baffling on these is built into the motor housing, and they clip on/off easily.
The post filter came up clean enough with an airline thank goodness
This bit is fun, you need to wire the motor back in but you can't fit it yet until the top shell is on. If you sit the motor correctly with the 3 rubber bushes located it sits squarely and evenly on the floor
Push the top housing on, noting to run the flex through first, then be VERY careful as the pedals pass through, the cord rewind pedal spring gets knocked off I find. If the pedals don't work, the top shell is not on properly, and once it's square you need to lever the locking tabs UP now until it latches back on!
Next, refit the exhaust diffuser
Then fit and screw on the bottom motor cover and finally you can stop holding something
Wheels on
« Reply #18 on: April 21, 2021, 09:58:40 pm »
Up to the front triangle now, screw the 2 halves of the shell together
Then fit the front wheels, angling them until the tabs pass then fitting the locating bar and screwing it together
Fit the pivoting end and circlip
Worked out it's easier to assemble this fully
And just drop the whole thing on
To fit to the machine, drop the top half of the main pivot on then pull the bottom on like so
Then do up all the screws
Then fit the cyclone unit
To the machine!
« Reply #19 on: April 21, 2021, 10:02:49 pm »
Whilst this was going on, or near enough to be date slotted into my images for this thread, the tangle free turbine tool got found and passed on. I'd never had one of these before, so more for curiosity...
The baseplate unscrews
As do the brushes
The rubber brushes themselves sit in a centre holder
Which just push out
This reveals some screws
The top shell lifts off
Revealing a wonderfully gritty pivot point
There are some screws at the top side next
« Reply #20 on: April 21, 2021, 10:06:06 pm »
The cogs push out of the bearing via a circlip removal
The other side is held on a mini chassis
This is the turbine part
Air intake filter
Unclips easily
This was also all washed and polished. Did you notice something missing from the previous exploded parts picture? That's right, all the tools! yey...
And we may as well start with the tangle free turbine tool
« Reply #21 on: April 21, 2021, 10:09:54 pm »
The turbine housing and main drive cog are reassembled and refitted
the main turning cogs pushed and clipped back in
I used the brush holder centres to help pull the cogs into the bearing from above
Has to be even
But eventually you can screw the midframe together
Then fit the brushes
And screw them down
Fit the baseplate and the tangle tool is done!
Re-assemble the wand if you bothered
« Reply #22 on: April 21, 2021, 10:12:44 pm »
Small tools got washed and popped back onto the holder
Long crevice tool apart
And together
And onto the floor head. Fit the wheel axles to the top frame now whilst it's apart
And clip it together
Fit the hose
Then fit the other end of the hose and screw it together
« Reply #23 on: April 21, 2021, 10:16:24 pm »
The other end of the hose will need some help
Next fit the wheels onto the shafts. A screwdriver behind the shaft helps here
The wheels move alot better now!
Turbine now, fit the top cap onto the moving bit, after a few drops of oil got dropped here and there
Fit the clear bracket to the turbine-air inlet seal
Fit said seal to the turbine housing
Screw the turbine housing together
Fit the belt over the cogs then slip the cog into the housing and refit the 2 screws
Check it all rotates freely and refit the brushroll cog now as it's way easier than with the housing fitted
« Reply #24 on: April 21, 2021, 10:20:25 pm »
Clip the turbine air intake filter on
Fit the belt pullet cover back on
And it's ready for
The brushroll housing itself
To refit the wheels on this generation, assemble as so
And push into place. Refit the rear baseplate too being sure the clip is fully seated in the middle, or it'll protrude and scrape/bind on carpeting
Screw the front on
Re-assemble the brushroll. Mvacs kindly sent me some spare red brushes as an experiment so some tweaking did happen, if your black brushes are worn right down then a set of red ones perks it right up!
« Reply #25 on: April 21, 2021, 10:25:24 pm »
Doing all of this utterly transformed it TBH and it worked MUCH better after
I even used it for a whole month
And then sold it to Mr HooverLux
Thanks for reading  :tiphat:
Offline dannysdysons123
« Reply #26 on: April 21, 2021, 10:34:21 pm »
 :bow:
(Attachment Link)
What a great read for half ten at night! Bloody hell, I've never seen a cinetic in person and I'm not desperate to get one not going to lie! Especially the upright as just the chassis and motor are a pain in the  :censored: so the only reason you'd see me with one is if I've had a joblot!
« Reply #27 on: April 22, 2021, 08:28:35 am »
Thanks! Don't blame you, it was really good when refurbished, but makes a loud howling noise from the airflow, and I hate the tools this whole era of dyson came with anyway... People seem to think their worth lots of money too... See them on fb for £150 looking well used, poor things!
:bow:
(Attachment Link)
« Reply #28 on: April 22, 2021, 11:20:20 pm »
:bow:
(Attachment Link)
Yeah I've seen these on the market place for way over what their worth, I also see brand new v10s for £470, surely that's overpriced considering their warrantys ran out months or even years ago! I also see 'refurbished' v10s and 11s but with no dock, charger or wand or cleaner head or even and attachments and they're up for like £250!
