take out put in hot water then pull the tabs out gently and hold .it takes a bit they will clip in then
Quote from: bluebumble485 on July 24, 2021, 02:19:32 pmtake out put in hot water then pull the tabs out gently and hold .it takes a bit they will clip in thenHow long do you leave it in for?
