Author Topic: Forward lock problem... again!  (Read 1386 times)
Offline Dysonboy123
« on: July 21, 2021, 07:16:22 PM »
I have a dc07 which it's forward lock keeps going out of place. Any ideas?
Offline dysondestijl
Re: Forward lock problem... again!
« Reply #1 on: July 22, 2021, 10:26:59 PM »
The lock hinges on the cleaner head are most likely warped or broken. Have you got another head you can try on it?
Offline Dysonboy123
« Reply #2 on: July 23, 2021, 07:28:08 AM »
It's not the one on the cleaner head, it's this one.
Offline bluebumble485
« Reply #3 on: July 24, 2021, 02:19:32 PM »
take out put in hot water then pull the tabs out gently and hold .it takes a bit they will clip in then
Offline Dysonboy123
« Reply #4 on: August 28, 2021, 06:55:24 PM »
How long do you leave it in for?
Offline Dysonboy123
« Reply #5 on: August 30, 2021, 02:15:59 PM »
Forward lock keeps coming out of place after reassembling it.  :angryman:
« Reply #6 on: August 30, 2021, 11:16:37 PM »
Probably 30 seconds in boiling water will make it pliable.
Offline Dysonboy123
« Reply #7 on: August 31, 2021, 11:52:59 AM »
I did that and fitted it back but keeps coming out of place.
« Reply #8 on: August 31, 2021, 11:00:10 PM »
I can only assume the tabs haven’t been bent back enough. Unless it’s damaged or the casing it’s in is damaged, and only you can tell that, not us!
Offline Dysonboy123
« Reply #9 on: September 01, 2021, 07:55:27 AM »
I did check it and it doesn't look damaged to me.
Offline Dysonboy123
« Reply #10 on: September 01, 2021, 10:25:06 AM »
I fitted it and it works but when I put the cleaner head back on it goes out of place.
