When I use the hose and block the end of the hose with my hand it trips this thing. It resets once I turn the vacuum off.
So I'm guessing it's normal for if the hand blocks it, but it seems even normal use is tripping it.
It seems like this is a safety so the motor doesn't burn out if there isn't decent air flow so I have purchased some filters thinking this may be what's causing it?
