Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
News:
With photos. Find it
>here<
Click
>here<
Home
Help
Login
Register
Dyson Models
Dyson DC14, DC17, DC27, DC28 and DC33
American Dyson DC17 - Stripdown & Refurbishment!
« previous
next »
Print
Pages: [
1
2
Go Down
Author
Topic: American Dyson DC17 - Stripdown & Refurbishment! (Read 1169 times)
beko1987
Member
Country:
Gender:
Let's take it apart!
on:
January 23, 2022, 06:53:11 PM »
Tweet
Many many years ago, our own Mr Parwaz purchased a DC17 from who knows where, but local to him in Birmingham. Some years after that he had a clearout and gave it to me, and I made it sit in a cold dark wet shed for another few months... Sometimes with company
But most often not. Until one day I finally bought it in to be looked at
As discovered here
//www.youtube.com/watch?v=xcW_tVN0Lsg
the belt was no good
The brushroll was knackered
And the motor rusty
But, it was all there, so the stripdown can commence
Logged
beko1987
Member
Country:
Gender:
Re: American Dyson DC17 - Stripdown & Refurbishment!
Reply #1 on:
January 23, 2022, 07:18:00 PM »
First thing is to drop the cable and remove the wand
Unpick the 3 locking tabs at the end of the wand
Then tap it out
Next, looking up inside the wand as it enters the plastic housing are 2 screws. Remove that, and pull the wand up and out. Then all the innards will fall out (If you careful as you do it you'll see how they all sit before it's too late)
The wand casing strips down even more
With the wand done, we can move to the bottom of the machine
Remove the suction elbow
Then this random bit of trim on the suction elbow...
Logged
beko1987
Member
Country:
Gender:
Reply #2 on:
January 23, 2022, 07:21:29 PM »
To release the hose is fun on this model... First, remove the lower cord hook...
This then gives you access to the rubber tabs you need to push up and out
But it wont come out yet
Nope, unclip the very end tool holder part of the other end of the hose
Then undo the middle rubber part
AND THEN you can remove the hose from the machine! And we can move on up the chassis and undo the screws for the switches
Pretty standard fare here
Unwire everything
Logged
beko1987
Member
Country:
Gender:
Reply #3 on:
January 23, 2022, 07:23:42 PM »
And the mains cable can be removed
And the chassis loom pulled down
The cyclone rubber seals can come off as we go
Time to lift the lid on the pre motor filter
There's a seal that lives in the end of the housing
Le filter
I removed the tool holder clips as I went
Logged
beko1987
Member
Country:
Gender:
Reply #4 on:
January 23, 2022, 07:26:26 PM »
Next we need access to the post motor filter, which is apparently in here
This cover comes off
and a mouldy, dry rotted disgusting post motor filter can be peeled off!
Moving down to the brushroll, we can remove the base plate
Then peel the rubber seal out
Then remove the rubber blade and seized rusty front wheels
Next up to remove are 2 springs
Logged
beko1987
Member
Country:
Gender:
Reply #5 on:
January 23, 2022, 07:30:41 PM »
The clear brushroll housing can now be unclipped from the outer one
But is still attached as the brushroll motor sits in here, and is hardwired in
Aha, no fear, we can just unplug the motor quickly... nope
At least the hose comes off nice and easily
The front bumper unclips from the clear housing
And the startings of the whole recline lock assembly can start to be removed with this cover
The rear wheels also need to be removed as they block things otherwise...
Logged
beko1987
Member
Country:
Gender:
Reply #6 on:
January 23, 2022, 07:35:43 PM »
There is 1 C-Clip on these machines
Then this is where the fun starts. The bottom of the machine comes off now. This drops the motor and everything else down too. What you end up with is
I'm very glad we unplugged it before we started yes...
It all sort of just hangs there too, it's awful, I presume there is some official way that makes it alot easier...
This is the recline switch for the brushroll
Motor out of the motor housing
Peel the crispy seal off
Then finally we can extract the spine loom
And disconnect the sodding brushroll motor
Logged
beko1987
Member
Country:
Gender:
Reply #7 on:
January 23, 2022, 07:39:22 PM »
I removed and checked the carbon brushes in the brushroll motor and they were good, whole motor looked fine bar the rusty case
I stripped the motor down to get the fans washed
Found yet more parts in the plastics
The changeover valve is held on with a hidden plastic clip, once unclipped it breaks down fairly nicely
There's a rubber seal under there
Finally the release valve can come out
That part done, it's time to move on to the cyclone
Logged
beko1987
Member
Country:
Gender:
Reply #8 on:
January 23, 2022, 07:43:51 PM »
The shroud pops off the upper housing
And to myself, who has only ever seen UK market dysons, looked immediately odd!
The utterly bloody disgusting nature of it all felt very familiar though...
The shroud unclips from the inner frame
The two lower cones unclip from the bottom end, uncovering 8 more
Then a white spacer piece
It seems it had turned into a 3 cone cyclone, must be a design feature, like modern cars turn off half the engine when idle etc
Inside here we can see all the screws that hold the top case on
The carry handle and the start of the bin emptying stuff unclips too
Logged
beko1987
Member
Country:
Gender:
Reply #9 on:
January 23, 2022, 07:47:51 PM »
The cyclone top seal comes out now
It unclogged itself then, BAGLESS IS BETTER!
Onto the bin now, the release catch for removing it completely comes off with its spring
Bin rod comes off
The bin flap seal can be removed and it's seals peeled off
And that was everything stripped down! Big pile of washing
24th April 2020 - looked like a decent day
This just went in the bin
Everything else got washed, polished and ready for re-assembly!
Logged
beko1987
Member
Country:
Gender:
Reply #10 on:
January 23, 2022, 08:31:15 PM »
I took the motor apart a bit more to clean it up and check the bearings were fine, which amazingly they were! De-grotted the carbons
and put it right back together
Bin seals now
Bin release rod
And through the magic of fresh polish and the camera it looks quite good
Latch and spring need to go on too
Logged
beko1987
Member
Country:
Gender:
Reply #11 on:
January 23, 2022, 08:34:31 PM »
We can take our full compliment of unclogged cyclones
Our fresh top sealing housing
With it's nice sturdy moulded rubber seal, none of this foam ballcocks
And sit it on top. Cyclone top cover next
Refit the top handle and red levers and spring
Then wonkily hold it together and do up the screws
Plastic firewall in
The 2 nipples can be screwed on nice and tight
Shroud time now
Logged
beko1987
Member
Country:
Gender:
Reply #12 on:
January 23, 2022, 08:38:28 PM »
The shroud snaps back on to the lower cone, then it can be clipped onto the top section
With the bin top seal fitted, the assembly is done and nice and clean!
Ugh, the next bit starts so simple, refit the release valve
Then take our non biohazard chassis
And refit the seal
Inside the changeover valve sits this plastic part. Refit the rubber seal to the top of it (it only goes one way IIRC)
This then clips inside the outer frame
The plastic retaining clip sits on the part first
Logged
beko1987
Member
Country:
Gender:
Reply #13 on:
January 23, 2022, 08:42:19 PM »
The changeover valve can be snapped in place now
The bushings for the cleanerhead pivot can go in now
I fed the chassis wiring loom in next
And got the motor housing out. Using hot glue, I stuck a normal DC14 size post motor filter pad to the housing
Which worked pretty well. The OEM part costs a fortune here in the UK and I'd rather not impede the airflow and kill the even harder to find motor
I tried to work out the more logical way of reassembling it now so the motor got wired up first
All the wires routed and the housing placed in the bottom chassis cover
Logged
beko1987
Member
Country:
Gender:
Reply #14 on:
January 23, 2022, 08:47:05 PM »
Sorry, fitted in the bottom of the top chassis! Because now, you can place the chassis into the cleanerhead housing and hang it off the back of your sofa so it all stays together...
And fit the bottom chassis cover and do up all the screws. Whilst keeping the brushroll motor connected and fed through it's place in the world
The post motor filter will work fine
And we should have this
Carbons refitted
I realised I needed a new wheel axle, so went into the shed and found one
Quick tidy up later and it's much better!
Can fit the wheels now
Then clip the bumper to the brushroll cover
Logged
Print
Pages: [
1
2
Go Up
« previous
next »
Dyson Models
