So, I unpacked my new X4 refurb this morning, assembled, and powered on to give it a go on my living room carpet (Wool, medium pile). After about the first 20 seconds or so, the machine switched itself off and I got the 'bag full' and 'check brush' lights came on together, blinking at a medium speed. Checked all the pipes, brush bar, the little dirt trap underneath and filters/bag. All looks good. Each time I switched it back on, the brushes spun for about 2 seconds and it switches off again with the same issue. Following the video posted by mvacs about taking the cover off and adjusting the little screw (Sensitivity adjustment for suction?), I attached the body and powered up with the hose attached with my thumb over the end, and the machine came back to life fully (This was before making any adjustments). Did I miss something here ?
Second, when I took the cover off, there appears to be a small piece of grey foam insulation (It sits just behind the white square filter but on the inside of the cover. This grey foam is torn in two and has obviously got caught at some point. Is this anything to be concerned about whilst running the machine ? I've taken it out for now in case it got sucked in somewhere it shouldn't.
Thanks,
Steve.
