Author Topic: Dyson vacuum cleaner mains fuses siuzes  (Read 2139 times)
Online grahamwin
« on: August 10, 2022, 12:45:06 pm »
Hi Dyson fans does any one know the correct size of fuse to fit the 13amp mains plugs fitted to the Dysons DC04, DC07, DC08 , DC14 ?
                                     Hoping someone can help - grahamwin.
grahamwin
Online grahamwin
Re: Dyson vacuum cleaner mains fuses siuzes
« Reply #1 on: August 12, 2022, 10:36:23 am »
I have been using a Dyson DC14 upright cleaner for a few years and it suddenly stopped working, I checked the original molded 13amp mains plug and it was fitted with a 5amp fuse and I replaced it with a new 5amp cartridge fuse. On switching on the DC14 it immediately blue the fuse again. So i have fitted a 13amp fuse to the mains wall plug and it now performs OK.
After searching online it seems that a 13amp fuse is the correct one but it had worked for a number of years with the 5amp fuse fitted without any problems ?
                             grahamwin
grahamwin
« Reply #2 on: August 14, 2022, 01:12:26 pm »
Nobody really uses 5a fuses anymore. 13a tends to be standard.
Perhaps its that your motor is older now and taking a bit more juice so the 5a isn't cutting it anymore.
