Author Topic: Converting from USA to UK spec  (Read 6117 times)
Offline sastek
« on: November 23, 2011, 11:56:28 pm »
Hi all,
I wonder if someone can tell me what parts I would need to change the USA Panasonic 110v motor to a Ydk 240v one
Stu
Offline MV Claire
    • Dyson & Sebo Specialists
Re: Converting from USA to UK spec
« Reply #1 on: November 24, 2011, 01:20:56 pm »
I remember we supplied some parts for someone that came back from America with a similar problem. I think we sent a full motor casing with the motor.
But, we should wait for our member Vacuum Cleaner House to see this as he will know for sure.
Offline Vacuum Cleaner House
  • Country: za
« Reply #2 on: November 30, 2011, 07:02:57 pm »
Hi sorry for the late reply , all he will need is the front motor rubber and the ydk motor. He is lucky those usa versions have a much better brush roll and clean allot better
« Reply #3 on: November 30, 2011, 07:10:14 pm »
By front, you mean the small motor rubber? The casing, retainer and back rubber are the same?
  • Country: za
« Reply #4 on: November 30, 2011, 07:32:59 pm »
By small do you mean the one at the back spindle side ? no hat stays the same, the big one in front by the fan that needs to be changed , but just check does he have a panasonic or ydk motor. if its ydk he just needs the motor.
« Reply #5 on: November 30, 2011, 07:59:39 pm »
He has a Panasonic one he says in the OP.
So he just needs a YDK replacement and the bigger of the two rubbers then?
  • Country: za
« Reply #6 on: November 30, 2011, 08:27:41 pm »
yep thats it and some new filters, especially the hepa one. can' fit new motor with old filters :)
Offline sastek
« Reply #7 on: November 30, 2011, 09:23:44 pm »
Hi guys, thanks for the replies, unfortunately, for me, I have already placed an order for a used housing, both rubbers and a motor from MVacs, not a probelm really cos the used mottor and rubbers were only a tenner!
Big thanks for the advice though  :thumbsup:
