Apologies for the very long delay in responding.
The changeover mechanism seems to work well and blocks/unblocks the feed tubes.
I replaced the drive belt to the clutch after I got a new one from you and I'm guessing that I must have got something out of alignment on the clutch as operating it, does not disengage the rolling brush, nor does putting it in the upright position.
The fact that that is continually running, even when in the 'upright' position, could that effect the suction as the roller is continually running ?
Thanks, Graham.
