Author Topic: Stuck Wand DC25  (Read 12660 times)
Offline tcatvac
Stuck Wand DC25
« on: December 11, 2011, 04:05:03 pm »
Can not pull out the wand, moves about 6 inches and stops!!!
Offline Angus Black
    • Dyson Medic
Re: Stuck Wand DC25
« Reply #1 on: December 12, 2011, 12:09:11 am »
You lift the end cover cap up, and pull the red cap attached to the tube out, yes?
Offline tcatvac
Re: Stuck Wand DC25
« Reply #2 on: December 12, 2011, 02:59:06 pm »
I have done that. It will pull up about 6 inches and will not move any more. Can not pull all the way out.
Online Dyson Tech
Re: Stuck Wand DC25
« Reply #3 on: December 13, 2011, 10:05:26 pm »
They can be a little stiff. Have you been enthusiastic with it? Was it coming out before OK?
Offline tcatvac
Re: Stuck Wand DC25
« Reply #4 on: December 13, 2011, 10:12:55 pm »
I GOT IT OUT WITH A LOT MORE FORCE. DID NOT WANT TO BREAK ANYTHING!
THANKS
Online Dyson Tech
Re: Stuck Wand DC25
« Reply #5 on: December 13, 2011, 10:29:24 pm »
THANKS
Glad you got fixed up.
Offline mark
Re: Stuck Wand DC25
« Reply #6 on: February 12, 2012, 03:05:37 pm »
My problem is that when I open the cap the cap will not lift at all.
Have tried being "vigorous" with it to no avail, any suggestions?
Mark
Offline kenemakid
Re: Stuck Wand DC25
« Reply #7 on: March 17, 2012, 11:23:06 am »
I cannot lift the wand at all. I open the cap. and the wand does not release at all. Fells like it is welded in there. I may have force it but would like to know what I am likely to break.
Re: Stuck Wand DC25
« Reply #8 on: March 17, 2012, 06:11:32 pm »
This is Dysons answer to this:
<a href="https://www.youtube.com/v/FJcNXrfQDVo" target="_blank" rel="noopener noreferrer" class="bbc_link bbc_flash_disabled new_win">https://www.youtube.com/v/FJcNXrfQDVo</a>
Try that first......
Offline kenemakid
Re: Stuck Wand DC25
« Reply #9 on: March 17, 2012, 09:37:27 pm »
 :thumbsup: Thanks for that but I have sorted it out now.  This was not the problem it was that the clear catch, inside the wand head had jammed.  WD40 and a good yank fixed it.  Thanks anyway
