Other Vacuum Cleaners & Site Suggestions > Miele Vacuum Cleaners
Miele S311i 'Esprit' - Stripdown and Refurb!
beko1987:
The Miele S3xxi machines are my favourite of them all. Reliable, bullet proof, nice and compact. I had this one given to me by another collector many years ago now
//www.youtube.com/watch?v=7xd4TwQxhVk
We start with the floorhead!
Not too rusty but a bit of a dent.
Full of fluff though
The red lint strips pop out of the baseplate, they were in good order.
The brushes pull out next, and reveal loads of packed up fluff
But that soon got removed
On this style of head, removing the wheel axle makes the whole neck come apart. I removed the locking latch too
beko1987:
Next the florhead pedal bar unclips, then the suxtion duct can be pulled out of the head shell and... oh dear
These 2 broken tabs are what stops the head pivoting around too far, and always break on this era of floorhead, which is a shame as their a wonderful tool. I moved on and took the bent end off the hose
Then onto the wand.
The adjustment knob pops off
Then a locking ring can be tapped out of the bottom of the join
The 2 halves of the wand can come apart now
The sprung adjustment piece is held in with a rubber ring, which pulls off
This reveals all the gunk inside the wands
Next comes the hose end
beko1987:
It just got washed whole
Finally we get to the machine! Tool door popped open
And the spring and door are removed
Small tools out
Upholstry tool splits down a bit more too
2 screws remove the bag full piston indicator
Which opens up
On a Miele S3xx, the hose inlet assembly is screwed in from inside. The big square box comes off, then splits in 2 once more (one or more of the locking tabs might/will be broken... Another common flaw)
Also removed are the bag door and it's hinges. With the bag door fully open, a locking tab aligns on each side of the hinge, allowing them to be popped off the pegs. The bag door pops off the hinges themselves with some persuasion.
beko1987:
2 Layers removed. Bag holder comes out now
Then the pre motor filter
Now we move onto the back, and 2 screws hold the switch pack on
It then pulls up and off, but will be held down by the connector plug.
It splits down nicely
I found this interesting, this isn't the lowest spec Miele S3xx, but it's the 2nd from the bottom, so it gets the power control and nothing else! The overheat warning lamp is blanked off, but under the blank has the warning triangle moulded in the solid plastic!
Next, undo the 4 screws holding the motor housing on
Then hold the 2 halves together, flip it upside down and lift the black base off the motor unit
And behold the nice, metal, lazy, massive airflow motor!
beko1987:
The motor is held in with a screw on the back housing bracket, and can be withdrawn that way. This front part for the fancase is easier to remove on it's own
The back bracket has 2 rubber bushings with it
The cord reel I just leave as it is, and wipe it as well as I can with a cloth and it being whole! Moving back to the bottom chassis, under the carrying handle are 2 screws, which remove a bit of trim
The furniture guard can be pulled off the chassis now
This blanking piece here is where the wires for the fancy electronic powered hose would go on the higher spec models
Out it comes, along with the back part of the pre motor filter housing
Wheels now! Pop the wheel axle up and remove the axle and wheel. Then, align the wheel swivel carrier to each of the bracket screws and remove both from the machine. The metal bracket seperates from the plastic housing with a tweak from a flathead screwdriver!
With that, everything was apart! Was summer at this time, so everything went outside for 8 minutes to dry!
I cleaned the rubber wheel that holds the cord reel steady and not just recline itself all the time
Navigation
[0] Message Index
[#] Next page
Go to full version
