Author Topic: SEBO X1.1 - Issues with auto height adjust on carpet  (Read 554 times)
Offline orion83
« on: January 19, 2024, 08:48:19 pm »
Hi all
My first post on the forum and hoping someone can give me their thoughts.
I have a 13 year old Sebo X1.1. Throughout those 13 years it has been flawless, however, just recently, I've noticed it has not been as effective on our carpets. It's as if it is riding just slightly too high and isn't grooming the carpets correctly. For info, we have the same carpet throughout the house which is only 18months old and it has a fair depth of pile.
At first I thought the brushroll was just worn, however after fitting a brand new, genuine one today (the 'blue bristles' type) it appears to have made no difference.
I've had the machine apart and checked the following:
  • Suction - as good as its always been and still works fine with the extension hose and turbo brush tool on the stairs.
  • Blockages - none. Completely clear right down to the brushroll.
  • Height adjust servo - appears to be working. When the cleaner is in its upright 'parked' position, it rises to its maximum height, and on our hardwood floor, it drops right down as expected. On the carpet, it does adjust itself, but, as I say, it feels like it's not lowering enough.
  • Belts - these look to be in good condition and are not slipping.
  • Motor - still loads of life left in the brushes and the commutator relatively clean.
  • PCB - no obvious damage i.e. no 'black marks' to infer that a resistor has burnt out etc.
  • Filters - replaced only a few bagfulls ago.
I was wondering if the issue could be the Belt Sensor Unit (Type 4 in my machine)?
Has anyone else ever had this issue and managed to resolve?
I did see an older forum post on here where the the person 'tricked' their Sebo X4 into the correct height, and then pulled the connector for the servo off the PCB so that it disabled the auto height adjust. I did actually test this earlier today too, and while that does 'work', I would prefer the machine operated as it's meant to.
Re: SEBO X1.1 - Issues with auto height adjust on carpet
« Reply #1 on: April 18, 2024, 02:50:34 pm »
Are the green lights working on the machine? The ones that denote it raising and lowering?
If it is a very deep pile carpet, it won't go too low or it won't get the airflow it needs. Has it been doing this on that carpet since it was fitted?
Offline orion83
« Reply #2 on: April 19, 2024, 10:19:25 am »
Hi
Thanks for getting back to me. I'll be honest after no-one repsonded after the first couple of weeks, I thought it was very much a case of no-one knew what else to suggest.
Since posting that though, after using my X1.1 a few more times, it now appears to be fine, and I'm wondering if there could have been an element of user error.
Our carpet is a reasonably deep pile, however, the high traffic areas are starting to get a little compressed and, on reflection, it was those areas it appeared to be struggling with to properly 'comb' the pile. I think it was a case of the self height adjust wasn't quick enough to adjust itself as the vaccum changed from unworn pile to the more worn pile if you get me, which was previously being made worse by the worn brush roller. The new brush roller and slowing down a bit has solved ther issue.
Hopefully onto another 13 years of fault free vacuuming  8)
« Reply #3 on: April 19, 2024, 11:55:08 am »
It slipped under our radar somehow, hence the late reply.
They can be a bit slow to adjust sometimes. But as you have done already, a new brushroll cures 99% of height control issues.
As it's only 15 years old, there's another decade or two in it yet. The Sebo we use in the showroom is from 1986.  :icon_nod:
