Author Topic: DC40 - vacuum shuts off after 5-15 min, starts working 1-2 hour later  (Read 578 times)
Offline invisible
Given: DC40 that served us for good amount of time, until tenants ruined it. After they moved out we discovered it is in completely non-working condition.
Every single freaking part was clogged with dog hair - canister, upper hose, lower under the ball hose, brush was not rotating. it took me 2 hours to completely disassemble, clean and re-assemble it.
I washed the canister and replaced filters with brand new ones. It started working again - great suction when it runs - both on carpet/rotating brush mode, as well as thru the hose. Picks up everything.
Now the problem - shut downs after 5-15 of working - motor just stops and there is complete silence. Unpluging/re-plugging does not help. Moving to another power outlet - does not help. I can confirm that there is reliable current/voltage supply. If I switch into carpet cleaning mode, the brush starts rotating. There is no suction or motor noise when brush starts rotating.
So I am assuming it is a thermal shutdown problem and when touching the ball, it is quite warm.
My extesive search over internet (did not know about this forum) found only this thread
https://www.fixya.com/support/t26537094-dyson_dc40_gets_hot_shuts_off_start
But it was aslo mentioned that overheating might be due to clogging. I don't see that happening in my case - just checked (after it shut down itself couple of hours ago). There is really good suction and again, hoses are clean.
So what I think it might be due to thermal protection fuse. This thread below indicating the same and mentioned in the thread that the problem was gone after fuse replacment:
https://www.reddit.com/r/VacuumCleaners/comments/djogu2/overheating_problem_with_a_dyson_dc39_ball/
If this really my case as well, could you please point me how to properly replace the the fuse and what would be the right part number for the replacement?
I guess I can get from Aliexpress pretty much anything.
And if it is NOT thermal fuse then what?
Thanks in advance.
Offline invisible
Re: DC40 - vacuum shuts off after 5-15 min, starts working 1-2 hour later
« Reply #1 on: March 19, 2024, 04:23:14 am »
P.S. Serial number is ET2-US-FAS1844A - don't know if this helps.
Online macman
« Reply #2 on: April 03, 2024, 01:03:43 pm »
Still got a blockage somewhere that is restricting the airflow? But must be fairly minor if it runs for 15 mins before shutting down.
Offline invisible
« Reply #3 on: April 16, 2024, 07:02:29 pm »
Where blockage can be? Canister is clean, all hoses are clean... But the ball gets hot fairly quickly. Where can I check?
Online macman
« Reply #4 on: April 16, 2024, 07:07:31 pm »
Try it with the HEPA filter removed. If OK, the filter is clogged.
Checked the internal ducting, changeover valve, bottom hose? Hot washed the cyclone?
Offline invisible
« Reply #5 on: April 16, 2024, 08:01:27 pm »
Guess I have to do all this...
If it does not help, would you recommend to replace thermal fuze? Should fuse replacment lead to reduced ball heating?
Online macman
« Reply #6 on: April 16, 2024, 08:42:36 pm »
If you have done none of those things, then you have no idea if the airpath is  clear or not.
Don't think the thermal fuse is the problem here,:check the simple stuff first.
Offline invisible
« Reply #7 on: April 16, 2024, 09:49:42 pm »
As always... thanks.
