Author Topic: Sebo Felix Pet stopped working altogether while using  (Read 333 times)
Offline Bentley14
« on: March 26, 2024, 09:31:15 am »
Stopped working while using. Changed fuse but nothing still
Any advice on how to identify the problem? Any thoughts what it might be?
Online macman
Re: Sebo Felix Pet stopped working altogether while using
« Reply #1 on: April 06, 2024, 02:25:02 pm »
Continuity test the cable from plug to switch, and switch to motor.
If the motor has blown you would normally hear a popping sound, and maybe some smoke.
« Reply #2 on: April 08, 2024, 08:40:01 pm »
Most likely the power cord has failed where it enters the handle.
Here's how to diagnose if it's just the flex at fault: plug it in and switch it on. Grasp the power cord a few inches from where it goes into the handle. Move it very gently and slowly up and down, side to side and maybe round in a circle. Try twisting it a little left and right. If the machine bursts into life, even for a moment while you are doing that, then it needs a replacement power cord. In this case, the cable has broken internally and a new one will fix it.
If that doesn't work, try doing the same a few inches back from the plug.  Very occasionally, they can fail where the wire goes into the plug.
