Author Topic: Is the end cap bearing block supposed to spin?  (Read 210 times)
Offline SK1
« on: April 27, 2024, 11:19:55 am »
Hello,
I'm trying to figure out if my end cap bearing is working properly on my X1.1. Is the central part that I've drawn an arrow to supposed to freely spin? Mine seems to not spin at all.
Thanks in advance for any help.
Offline Sam1979
Re: Is the end cap bearing block supposed to spin?
« Reply #1 on: April 27, 2024, 04:12:06 pm »
I'm fairly sure it's not. I've got 2 X4s and both have that plain bearing/bushing in the same slightly complicated looking fitting. It seems to have some movement to allow it to accomodate the brush shaft/relative angles when refitting etc, but it doesn't rotate. Edit: not meant to rotate is what I meant, reply to title e.g. it probably is working.
Offline SK1
« Reply #2 on: April 27, 2024, 05:40:38 pm »
Thank you Sam, that's really helpful. Saved me from ordering a part I don't need.
Offline JamieLincs
« Reply #3 on: April 27, 2024, 09:28:07 pm »
Good to know this. I'd been wondering the same thing.
It's difficult to know what's normal when you only have one of something and no new version to compare it to.
« Reply #4 on: May 05, 2024, 03:38:59 pm »
Sam is right, they tilt and move a bit, but don't spin as such. The shaft of the brushroll spins within it, seemingly without a proper bearing. It sounds honky plonky but it works very well. But just to confuse you, Sebo call it a "bearing block".  :chuckle:
