Author Topic: can i use DC40 DC41 DC55 DC75 Back Telescopic Hose for dc18 slim  (Read 1171 times)
Offline mmjojomm
Hi All, as per the title.
I understand the fittings are different but if the length is roughly the same and the diameter is the same I can refit both ends with no problem. The old one is splitting now quite often which results in me shortening it every so often and it's quite a mission to find a replacement that doesn't cost 100 quid.
thanks
Re: can i use DC40 DC41 DC55 DC75 Back Telescopic Hose for dc18 slim
« Reply #1 on: May 21, 2024, 02:53:18 pm »
If the hose diameter is the same and you feel confident to refit the ends, I don't see why not.
DC18 hoses are thin on the ground now, indeed.
Offline mmjojomm
« Reply #2 on: May 21, 2024, 03:52:07 pm »
Hi, thank you, but that was my question really, if someone know if the hoses are of the same diameter?
thanks
« Reply #3 on: May 22, 2024, 11:08:35 am »
Tell me the outer diameter of your hose and I'll check.
Offline mmjojomm
« Reply #4 on: May 22, 2024, 08:46:32 pm »
hi, its about 38mm on the coils.
thanks
« Reply #5 on: May 24, 2024, 01:15:23 pm »
DC07, DC40/41, DC25 are all 44mm on the outer coils.
This DC04 hose is 39mm on the outer coils and looks to be the best candidate.
« Reply #6 on: June 12, 2024, 01:15:07 pm »
Just as an update, we do have some recycled Dyson DC18 hoses in stock.
