Author Topic: Weak suction at the cleaner.  (Read 603 times)
Offline Dyson4u
« on: June 06, 2024, 03:08:39 pm »
My DC04 has excellent suction at the wand,  but the suction when reclined is weak. Do you know what the issue is?  I've checked all the filters, checked the seal and checked to see if there's any blockage.
Re: Weak suction at the cleaner.
« Reply #1 on: June 14, 2024, 12:34:46 pm »
How are you deciding it has weak suction when reclined?
Offline Dyson4u
« Reply #2 on: June 14, 2024, 03:04:24 pm »
When reclining it, it  skims the carpet and doesn't seem to pick up that much.
« Reply #3 on: June 18, 2024, 12:22:02 pm »
Is this a clutched or non-clutched machine?
Offline Dyson4u
« Reply #4 on: June 18, 2024, 08:53:24 pm »
Non clutched. Silver and lime.
« Reply #5 on: June 19, 2024, 11:30:06 am »
It will be the cleanerhead not making contact with the floor. Recline it and look at it from the side, the back will be lifted up and not flat to the floor. To cure it, twist the hose until it makes contact correctly. It's common when you have had it apart. More common if the hose is a copy one as they are too stiff.
Offline Dyson4u
« Reply #6 on: June 24, 2024, 10:16:13 am »
Still the same. I might use it for parts then.
DC04 Spare Parts
