Author Topic: Miele C3 fault Model SGDF3  (Read 361 times)
Offline pan50
« on: June 08, 2024, 01:13:00 pm »
Hi i have an issue with this vac, when pressing the power the Orange power selector icon briefly lights up then nothing.
I have checked the TOC all connections seem fine. Motor is clean and brushes still have plenty of meat left.
any ideas what the issue is?
Offline Mike Aberdeen
Re: Miele C3 fault Model SGDF3
« Reply #1 on: June 14, 2024, 12:41:23 pm »
The control board, often referred to as the PCB (Printed Circuit Board), can fail. Symptoms of a faulty control board include the power selector icon lighting up briefly and then the vacuum shutting off. This is a relatively common issue with some Miele models.
Given the specific symptom, the control board (PCB) and its components (such as capacitors and the triac) are likely suspects.
Offline pan50
« Reply #2 on: June 14, 2024, 09:37:51 pm »
Thanks for your reply I guess ill have to look into testing the caps and have a closer look at the triac. do you think there could be dry joints on the PCB?
