Author Topic: DC11 Bleed Valve  (Read 557 times)
Offline julien
  • Country: fr
DC11 Bleed Valve
« on: July 03, 2024, 05:02:27 pm »
Hi everyone... I recently restored my DC11...
I blocked the suction for a few seconds by hand to check the bleed valve working good... but nothing moves...
Does anyone know how it works?
Thanks for your reply
Julien
Offline MV Claire
    • Dyson & Sebo Specialists
Re: DC11 Bleed Valve
« Reply #1 on: July 05, 2024, 01:05:02 pm »
You should find the answer on this topic: >>DC11 strip down topic<<
Offline julien
  • Country: fr
« Reply #2 on: July 06, 2024, 03:21:39 pm »
I already seen this topic, it's thanks to this that I achieved to reassembly the cyclone of my DC11 and found your forum
Many thanks to the poster Beko1987  :thumbsup:
But no real explanation on how the bleed valve works (opening and closing conditions and states)
The bleed valve looks like to this
Offline Dysonboy
« Reply #3 on: July 07, 2024, 10:47:56 pm »
Its just a spring loaded piston. When a blockage anywhere occurs i.e. puttig your hand over this creates a vacuum that pressure over comes the springs pressure.
Theres no way it can fail so if it's not functioning it means your not building adequate vacuum to overcome the spring so you have a leak somewhere on the machine.
« Reply #4 on: July 31, 2024, 07:04:54 pm »
When the pressure behind it builds up (I don't know how that works either
