Author Topic: noise from dyson dc 04  (Read 5512 times)
Offline bordercollieblue
« on: February 14, 2012, 03:54:43 PM »
I have a dyson dc04 its been great up till now I took it apart and cleaned it because of the noise, the brush still going round but still makes a noise like there is something stuck in it the noise seems to be coming from a black part inside
Offline Angus Black
    • Dyson Medic
Re: noise from dyson dc 04
« Reply #1 on: February 16, 2012, 09:42:28 AM »
Did you take the brush roll out and check the bearings were not seized?
« Reply #2 on: February 21, 2012, 02:30:56 AM »
Is this a ratcheting noise?
Offline daveb3650
« Reply #3 on: May 20, 2012, 06:35:49 PM »
mine makes a horrible ratcheting noise.........what is it?
Offline bluebumble485
« Reply #4 on: May 20, 2012, 09:15:18 PM »
have you twisted the belt on the clutch ?
take off and make sure then do again
good luck
Offline daveb3650
« Reply #5 on: May 20, 2012, 09:26:25 PM »
I did unhook the belt from the roller.....but though I had it back on properly......is it just a case of doing it again..or is there a way of dismantling things further...I dont have any instructions and was boing it blind.......I unloosened the 3 screws on the head, lifted the cover out of the way.....cleaned it.......but did have to move the belt to get in properley,,,,,I then slid the roller back under the belt and fit the head back together.....
Does this sound like my belt is miss aligned or something - thanks
« Reply #6 on: May 20, 2012, 10:33:08 PM »
normal ones have dyson on the outside
check with the cover off it is not twisted replace cover etc then brush roller look for the dyson letters most have it
try again if it still makes rachet noise change clutch ,look on youtube there is a video showing you how
good luck
Offline daveb3650
« Reply #7 on: May 21, 2012, 01:14:56 AM »
Many Thanks........
This is the original stuff so the belt will show Dyson.......... Me thinks I cud be changing the clutch....
Cheers again for you help
Daveb3650
