Author Topic: Dyson DC04 - Noise like something jammed when I change carpet mode  (Read 21164 times)
Offline daveb3650
Hi... I had the bottom off the DC04 this morning so I could clead the roller.... when I put it back together all seems fine,,,that is til I move the foot control from laminate floor to carpet mode.......after a second or two its like something is rattling around......It's a helluva noise...... any ideas before it goes out of the window...
Daveb3650
Offline MV Claire
    • Dyson & Sebo Specialists
Re: Dyson DC04 - Noise like something jammed when I change carpet mode
« Reply #1 on: May 21, 2012, 02:07:49 pm »
It sounds like you have trapped the belt on the soleplate or the clutch is faulty?
Offline bluebumble485
« Reply #2 on: May 21, 2012, 06:00:47 pm »
be very carefull doing this i mean it
run the dyson with the sole plate off then move the head down as mv says clutch or sole plate
stay with it you can do it
Offline daveb3650
« Reply #3 on: May 21, 2012, 06:58:12 pm »
Thanks for the reply....im having a look in ten mins....... it was working absolutely fine til i opened it to remove loads of tangled threads around roller......
Thx again...
Are there any videos to show the proper procedure ?
Offline daveb3650
« Reply #4 on: May 21, 2012, 07:33:31 pm »
Just had a look on Youtube...... it looks well within my capabilities...... fingers crossed eh!!
« Reply #5 on: May 21, 2012, 09:35:58 pm »
you will get a used clutch from mancheter vacs i am sure
i can do one in 15 mins the first one took one and a half hours 10 year ago
stay calm watch the video as yoi go jobs a gud un
Offline daveb3650
« Reply #6 on: May 21, 2012, 10:00:47 pm »
The vacuum works fine on laminate.......but its a horrible noise when I move the clutch,,,,, also if im using the extension hose then all is fine and it sucks like a good un'
There are new clutch's on ebay for under £16 inc delivery....
I'll try around...
Many Thanks to all
Dave
Offline daveb3650
« Reply #7 on: May 21, 2012, 10:04:51 pm »
Manchester Vacs - recon one for under a tenner inc delivery...looks like that where im heading...
Offline daveb3650
« Reply #8 on: May 22, 2012, 08:16:15 pm »
I did this........ no noise til i moved the handle from the upright position....then a bloody awful racket....
« Reply #9 on: May 22, 2012, 09:09:48 pm »
when the handle is in the upright position the clutch is not engaged
when you lean back the clutch cuts in change the clutch it all says its gone
wait to see if mv agree i am sure they will
Offline daveb3650
« Reply #10 on: May 22, 2012, 10:10:24 pm »
Thanks Bluebumble.... i've ordered some parts from MV..... with a bit luck this tip will get a proper hoover at the weekend,,,,i'll let you know how i've managed...
Thanks for your help -much appreciated,
Daveb3650
Online Dyson Tech
« Reply #11 on: May 23, 2012, 03:11:52 pm »
Yes, it sounds like the clutch to me as BB said above. The noise is a very loud ratchet type noise.
Offline daveb3650
« Reply #12 on: May 23, 2012, 07:33:37 pm »
That descibes the noise exactly....... Thx for your help..
Offline daveb3650
« Reply #13 on: May 25, 2012, 09:46:12 pm »
The parts we ordered on Tues night..... nowt here yet so nothing to report yet,,,,,,, im itching to get cracking tho
i'll update you tomorrow if they turn up....
Online Dyson Tech
« Reply #14 on: May 27, 2012, 11:56:38 am »
Shop is closed Wednesday so they would have been mailed Thursday.
