Author Topic: DC14 wont turn on  (Read 9816 times)
Offline dandm
DC14 wont turn on
« on: June 19, 2012, 11:15:47 pm »
We have a DC14 which has been working (in as much as any Dyson works) until today. Now pressing the on/off button does nothing.
I have dismantled the switch cover and checked the switch is working by buzzing out with a multimeter. Also checked the fuse. There are no tubes or filters blocked and the brushes will revolve freely if hand turned. Is there anything else I should check or does it sound like the motor has failed?
Offline __russ__
Re: DC14 wont turn on
« Reply #1 on: June 20, 2012, 12:05:50 pm »
Did the motor stop during use and if so, did it change tone before it stopped?
Offline dandm
« Reply #2 on: June 20, 2012, 08:26:38 pm »
I wasnt using it, but SWMBO says it sort of started and barely got going before dieing. From her description the tone wasnt normal for the short time it started.
« Reply #3 on: June 20, 2012, 09:00:00 pm »
Assuming the power cable is OK, that sounds like the motor died.
Offline __russ__
« Reply #4 on: June 20, 2012, 11:22:42 pm »
Assuming the power cable is OK, that sounds like the motor died. (Attachment Link)
Great emoticon you got there  :biglaugh:
Yep definitely sounds like the motor has had it I'm afraid!
« Reply #5 on: June 21, 2012, 05:15:27 pm »
I just added it.  ;)
 :dead-dyson: :dead-dyson: :dead-dyson:
Offline dandm
« Reply #6 on: June 24, 2012, 11:33:19 pm »
I just added it.  ;)
Need to add one for a resurection as well :)
Motor ordered, received and fitted. Dyson now working again.
Thanks for your help
