Author Topic: suck carpet not as good  (Read 3446 times)
Offline boyde
« on: August 26, 2012, 02:08:08 PM »
we got given a dc04 a few years back ,it used to lift the carpet ,now it just picks up but now it doesn't lift the carpet,i have tried everything,was thinkig of paying dyson to service it,dont want to buy new as i am happy with the dc04
Offline macman
Re: suck carpet not as good
« Reply #1 on: August 26, 2012, 11:13:46 PM »
Have you cleaned/changed both filters, checked all the airways for blockages?
Is there still good suction from the wand? if so, the problem is in the airflow between the cleaner head and changeover valve. Checked the bottom hose for blockages or splits?
If wand suction is poor too, then I'd be dismantling and pressure washing or steam cleaning the cyclone.
« Reply #2 on: August 27, 2012, 11:49:10 AM »
was thinking of paying dyson to service it,
Seventy odd quid with Dyson. :o
You can DIY easily with a little advice.
Offline boyde
« Reply #3 on: August 27, 2012, 12:44:13 PM »
I have checked loads, I have done the following.
1. took cone out and blew dust out with compressed air.
2. washed filters
3. checked pipes for blockages
4. checked rubber seals
5. checked brush bar for hair
6 checked bush bar and does spin.
suction from the wand is second to none, I picked up a heavy weight with no problem.
I either need new filters (can't see that being the main cause?)
took flexi hose off, filled with water, no leaks.
I have considered, dyson call out or buying the dc33
there is no resistance whan pushing along I am sure it used to suck the carpet, it still picks up, i sprinkled flour on the floor and it picked that up
Offline macman
« Reply #4 on: August 27, 2012, 01:45:51 PM »
Filters aren't the issue if you have good wand suction, the issue is in the cleaner head or the linking airway.
Have you checked the bottom hose (the short clear hose between brushroll holder and the main body? A split in that, or poor attachment at either end, will greatly reduce cleaner head suction. Remove it and see if there is suction in the airway on the main body. If not then there must be a blockage in that airway that you have missed.
