Author Topic: DC01 motor problems - advice needed please  (Read 6109 times)
Offline Russell Hobbs
« on: September 01, 2012, 12:35:08 PM »
Looking for a bit of advice regarding a problem I am having repairing a DC01.
Last week there was a lot of banging and clattering from the motor housing and a loss of suction.  I suspected a new motor of which I know are hard to source.  Having taken it to pieces i found the motor to be fine but the problem was at the end of the armature where there is a fan like plate structure which I assume creates the suction. The whole structure had disintegrated hence the banging noise.  I have no idea what it is called or even if it is available as a spare.
The irony is that the motor is fine and works well and assuming I can repair this, it will benefit from a new pair of brushes.  Those I know are easy to get hold of.
All help gratefully received.
Many thanks
Forgot to mention - the motor is an Armtek
Offline Angus Black
    • Dyson Medic
Re: DC01 motor problems - advice needed please
« Reply #1 on: September 01, 2012, 07:17:14 PM »
You could use a burned out motor I suppose and make a good one from the two. No parts are available for those motors.
However, they are available good and used. I would just swap it for what its worth.
« Reply #2 on: September 01, 2012, 07:21:07 PM »
Thanks for that. I kinda suspected that might be the case.  I will keep searching.  Cheers
Offline macman
« Reply #3 on: September 01, 2012, 10:51:13 PM »
Used motors are occasionally offered on eBay for the DC01, it depends which model of motor. There is an Ametek on there at present.
« Reply #4 on: September 01, 2012, 11:55:32 PM »
Thanks - just seen it
« Reply #5 on: September 02, 2012, 07:35:38 PM »
We have Ametek DC01 motors too in case of need.
« Reply #6 on: January 17, 2015, 10:36:48 PM »
Just found this post, I came across a DC01 last week with Ametek motor that had done the same thing, I've put it to one side to explore at a later date.
DC01 Spare Parts
