Author Topic: DC07 Will Not Drop To The Floor - Have To Use My Foot?  (Read 7863 times)
Offline backman56
« on: December 29, 2010, 03:05:41 am »
i installed new belt,clutch assy, new pickup hose at brush assy,my problem now is the brush assy will not drop to floor it drops real slow,or i keep having to push the brush assy down with my foot.what is wrong i put a new hose on it it was suppose to be shorter.
any help i would  appreciate,   Rick in usa--pennsylvania
Offline Vacuum Cleaner House
  • Country: za
« Reply #1 on: January 01, 2011, 07:44:08 am »
If by brush ass you mean just the swivel brush mount and not the cleaner head then
I had this same problem with a USA model dc14 brought to my shop.
It turns out to be the hose as this acts as a spring to allow the brush assembely to sit flush to the carpet.
Just turn the hose a few degrees .
Just check that the hose is the correct lenth some after market ones are shorter or longer, compair it to your old one if longer cut it.
Online Dyson Tech
« Reply #2 on: January 08, 2011, 11:51:07 pm »
I agree.  :icon_nod:
Offline ted343
Re: DC07 Will Not Drop To The Floor - Have To Use My Foot?
« Reply #3 on: January 13, 2011, 08:40:02 pm »
I had a similar problem, but then the whole DC07 went kerplut and i got a DC23 instead
« Reply #4 on: January 14, 2011, 09:31:53 am »
How do you find the DC23 Ted? Do you rate it?
Offline Ilovemysebo22
« Reply #5 on: February 16, 2018, 10:31:19 pm »
You have over tightened the screw under the u-bend tube
