Author Topic: Dyson Fans Copied From Japanese Design?  (Read 8355 times)
« on: January 02, 2011, 03:16:45 AM »
The Daily Telegraph recently reported that the Dyson bladeless fan was first developed 30 years ago by a Japanese company, according to documents filed at the Intellectual Property Office. The desktop fan, costing £200, has won plaudits both in Britain and America for its sleek design and clever engineering. The Air Multiplier works by sucking in air at the base, and pushing it out at speed through a thin gap in the fan's ring, meaning there are no visible blades in the fan.
However, documents indicate that a Japanese company, Tokyo Shibaura Electric, developed a nearly identical idea of a bladeless desktop fan in 1981. It is understood it was never manufactured.
        Left: Dyson patent (2009) and right: Tokyo Shibaura patent (1981)
Documents at the Intellectual Property Office, formerly the Patent Office, indicate that Dyson re-submitted its application for a worldwide patent last year after the IPO ruled that its initial design was too similar to the Japanese invention. The Dyson version, "cannot be considered novel or cannot be considered to involve an inventive step", the initial ruling from the IPO suggested.
Patents expire after 20 years, but even after that date they can not be submitted by a different person or company unless they have been changed or improved upon.
Dyson's most recent patent applications, which are still pending, have been changed to highlight a key design feature of the Air Multiplier: a Coanda surface. This is the aerofoil ramp over which the air is pushed out of the ring of the fan. Because of the angle of the Coanda surface, the air sucks in surrounding air into the air flow, creating a smooth and powerful blast of air for any office worker using the fan.
Gill Smith, the head of Dyson's patent department, said:
Quote
"We wouldn't dream of denying that the Japanese arrangement and our fan look very similar. The difference is all in the technology. We've spent many years developing the Coanda surface. The Japanese version does not have this feature."
She said that she "absolutely expected" Dyson to be granted a patent for its Air Multiplier. The most recent patent application has not fallen into the "not novel" category that the initial application suffered from.
Dyson is adamant that its bladeless fan is completely different from the earlier Japanese version, with its design director Peter Gammack, writing an article for Telegraph, defending the Air Multiplier. Here it is:
Quote from: Peter Gammack, Design director, Dyson
I have been at Dyson for twenty years and was heavily involved in the Air Multiplier fan’s development. I would like to clarify some confusion over how our fan works and how it is different from the Japanese disclosure and other industrial devices.
In our fan:
  • A mixed-flow impeller draws in air which is then pushed up into the loop.
  • The air exits the aperture at high velocity and creates an area of low pressure that draws in air from behind the fan.
  • The fast-moving air follows the precisely designed 16° aerofoil-shaped ramp (the Coanda effect) which creates a further area of low pressure, drawing in even more air.
  • As the air jet leaves the front of the loop, more air is entrained due to ‘viscous shearing’, amplifying the initial airflow even further.
The Japanese design does not make use of the Coanda effect as ours does. It simply uses a motor in the base to force air out of the ring.
The industrial devices work from compressed air lines, and are not suited to the pressures and flow rates we are using for a desk fan.
Anyone that works in design or engineering will appreciate the incremental changes that occur when developing something new. An engineering principle applied in a different way still takes a huge amount of time, effort and development to get right. The reason why no other bladeless fan has come to market is because it’s very difficult to get right – I can vouch for that.
Patent attornies said it was quite normal for companies to submit patents and for the IPO to discover similar inventions when they undertook its "search", a due diligence process the authorities always do before granting patents.
Russell Barton, partner at law firm Withers Rogers, said: "The majority of inventions do take old technology and improve on them. But you do need to demonstrate novelty to be granted a patent."
Source
Offline Vacuum Cleaner House
  • Country: za
Re: Dyson Fans Copied From Japanese Design?
« Reply #1 on: January 06, 2011, 10:03:51 AM »
It is amazing how many ideas there are out there that have been patented and then shelved.
When I worked for a major vacuum cleaner company  I saw many things that still have not come out yet .
Imagine if James dyson had sold his idea to Hoover or Electrolux it would have just been shelved only to come out in ten or twenty years when some one else tried to make a cyclone vacuum.
One of the things I like about Dyson is that they tend to put the ideas into production instead of shelving them due to cost like other company's do.
« Reply #2 on: January 06, 2011, 07:09:52 PM »
I haven't got one of these yet; I guess I'll have to have one on my desk for the summer. Do they market the Dyson fans in South Africa? If so, what kind of money are they there?
  • Country: za
« Reply #3 on: January 07, 2011, 06:14:54 PM »
Unfortunately no they don't, seen one or two and saw a sample one at HO but I don't know if they will bring it out.
I don't think many South Africans will  drop +- £300.00 for a fan no matter how good it is, you can get Aircon fitted for that price here and considering its 6 pm now in Cape Town and It is +30deg Celsius >: I would go for aircon as well .
A really good 18" AEG floor fan will only set you back about £25.00 and we like the buffeting; I have 10 fans on in my house at the moment ;D
So I think it would be a bit on the expensive side here.
« Reply #4 on: January 09, 2011, 02:05:40 AM »
No doubt the price will come down soon enough now the novelty has worn off.
