Author Topic: YDK motor  (Read 4315 times)
Offline skypilot
YDK motor
« on: January 02, 2013, 02:05:11 PM »
Our DC01 has what appears to be a motor burnout - smell of burning and clonks from the motor. I've stripped it down and removed the motor, which has YV-511 stamped on it. As all the info I've seen refers to YV-940, will a replacement armature and bearings fit or am I wasting my time?  There's also a capacitor - does this fail and should it be checked?
I'd like to keep the DC01 going but I'm not sure if the new parts will fit. The motor spindle on the 511 seems to be much shorter than the one on the 940.
Offline aceone
Re: YDK motor
« Reply #1 on: January 03, 2013, 07:22:57 PM »
Hi.... since it is a dc01 i assume it is the original motor,so im gussing it has had alot of use,i would recommend replacing the motor,however after saying that i beleive they have ceased making that motor,best speak to Manchester Vacs on here they may be able to supply you with a recon motor    good luck
Re: YDK motor
« Reply #2 on: January 04, 2013, 12:44:15 PM »
A YV-511 is a DC04 motor.
A DC01 should have a YV-940 or a YV-540 in.
DC01 Spare Parts
