Dyson Models
Cylinder & Canister Dysons
DC02 On/Off Switch
Topic: DC02 On/Off Switch (Read 9405 times)
gbealnz
DC02 On/Off Switch
May 10, 2013, 09:00:59 am »
Hello all, new here. We have an old DC02, been a great cleaner, gave me grief today, went "poof/pop" and wouldn't start. Thought the poof/pop was a fuse, but the wall socket was fine.
In the end curiosity got the better of me, and I have it dismantled on the work bench. In doing this the leads have come free from the inn/off switch, and I could use some help with what lead goes to what terminal on the switch.
The realist in me says this won't fix it, but I need to try this first, before I dump it.
My electrical (using a multi-meter) is zip, I can perform a continuity test of course, but watts/ohms, etc, forget it.
Anyone able to point me to a picture or explain which coloured lead goes to what terminal. Please.
Gary
MVacs
Administrator
Re: DC02 On/Off Switch
May 10, 2013, 09:05:15 am »
Are the wires feeding the switch both the same colour? Is it a two or four terminal switch?
Sebo repairs in Manchester
Dyson repairs in Manchester
Sebo spares in London
gbealnz
May 10, 2013, 09:24:17 am »
Thank you for the reply.
Um, not sure about the colours, from memory blue and white and two others.
Yes, 4 contact switch.
Gary
Dyson Tech
Global Moderator
May 10, 2013, 12:37:38 pm »
That doesn't sound standard.
Can you post a photo of the switch terminals and the wires that feed it please?
Photo tutorial here:
https://manchestervacs.co.uk/DysonForum/index.php/topic,506.0.html
Sebo repairs Manchester
Dyson repairs Manchester
gbealnz
May 10, 2013, 09:44:34 pm »
Appreciative of your help, we couldn't be further apart, globally.
Pictures attached (I hope).
The four wires are black, red, dark blue, and brown, or close to it.
The switch has a total of four spade connector posts. On each side there are letters "D" and "E". A pair of D and E in other words.
Thank you again.
Gary
MVacs
Administrator
May 11, 2013, 07:19:33 pm »
That's a really early one. Our tech needs to answer that on Monday really. Unless anyone else knows meanwhile..........
What is standard live and neutral colours in Oz? Are you on red/black? brown/blue? Or something else?
gbealnz
May 11, 2013, 09:15:57 pm »
Yep, an early on alright, we've had it for ages. It's demise meant I had to buy a replacement, and get a DC39 in it's place. I'd still like to repair this one, a great hand-me-down.
I didn't have a clue what coloured wires we have in NZ (not Oz) but checked and saw this
http://en.wikipedia.org/wiki/Electrical_wiring
I'll sit tight until your boffins decision on Monday. A good excuse not to vacuum the floors anyway.
Gary
MVacs
Administrator
May 11, 2013, 10:26:21 pm »
I see from that you have both brown and red as lives there and blue and black as neutral. Similar to here.
I PM'd SmartAlec for you and linked him the topic. He is an Aussie with a Dyson shop. I also PMd a guy in South Africa, he knows loads too.
Dyson Tech
Global Moderator
May 13, 2013, 12:51:12 pm »
Although we don't have that wiring configuration here on DC02's, the wiring codes appear the same so it *should* be like this......
gbealnz
May 17, 2013, 10:46:31 pm »
Wow, thank you, for some reason I missed this, didn't receive a notification that there was a reply.
Again, thank you. I'll give this a go.
Gary
gbealnz
May 18, 2013, 10:00:07 pm »
And an update. A huge thank you to all that helped, I really am greatly appreciative.
Firstly, I connected the on/off switch in the manner that was pictured above. Curiosity then got the better of me. While my use and knowledge of a multi-meter is very limited, I tried the continuity test on the power cord, to see if there was continuity between the AC plug and the switch. There was on one side but the other not. In the end I traced it to a "break" in the cable, between the power cord coming in, and the centre hub. The gut feeling is that stress from pulling the cord out has severed the blue cable, not really that visible, but enough to give the issue.
In the end I cut the lead off, and re-did the whole area where it attaches.
I was surprised as all get out when I powered it up, and it worked. Yessssss.
Thank you all again.
Gary
Dyson Tech
Global Moderator
Reply #11 on:
May 20, 2013, 11:54:36 am »
Glad you got fixed up.
Dyson Models
DC02 On/Off Switch
