Author Topic: DC04 Zorbster brushbar  (Read 9174 times)
Offline bluetntmo
« on: June 29, 2013, 08:51:46 am »
Hi
I have a DC04 Zorbster purple and grey it has sat in the shed for some years!
In a moment of madness last week I decided to get it out and have a look at it! I searched for what might be wrong with it not picking up!
Thanks to the useful info on here I washed the filters and ordered new ones, mean while I took the brushbar out and cleaned all the hairs and fluff off it.
NOW the suction is much better BUT the brushbar doesn't turn. I have read the posts about replacing the clutch and removing the clutch, but nothing showing what a plonker I have been cause I didn't keep the belt under tension, just pulled it and pulled the brushbar out.
What can I do?????
thanks
Re: DC04 Zorbster brushbar
« Reply #1 on: June 29, 2013, 04:38:49 pm »
Do you need a brush roll removal tool?
See here: https://manchestervacs.co.uk/DysonForum/index.php/topic,392.msg894.html#msg894
If I understood you correctly.......
Offline bluetntmo
« Reply #2 on: June 29, 2013, 05:41:22 pm »
No thanks used a couple of screwdrivers what I need is how to get the clutch out of my DC04 Zorbster as the pin on the side won't come out !!!! Help
« Reply #3 on: June 29, 2013, 06:19:03 pm »
Try this: http://dysonmedic.co.uk/how-to-replace-the-clutch-on-a-dyson-dc04/
Edit: Ahh, you mean the little camber thingy. I'll ask our tech on Monday.
Offline bluetntmo
« Reply #4 on: July 03, 2013, 01:43:45 pm »
Sorted thanks had to take the front off no sweat just 2 c clips! After much effort got new belts on from new clutch reassembled now got a ratchet noise and brush bar is not turning freely. Going to get a belt removal tool before I take it apart again!!!😰
Just about to order one with a new brush bar😋
« Reply #5 on: July 03, 2013, 10:43:54 pm »
If you encounter any glitches with our site, do bear with us - we are doing a server swap on Thursday sometime.
PS - we were so busy Tuesday that by the time I asked him about this, we were closing and the computers were off. And we are closed Wednesdays. So sorry about that, but glad you worked it out.
Offline bluetntmo
« Reply #6 on: July 08, 2013, 09:12:57 pm »
OK have fitted the new brush bar and everything is rotating freely. I have also fitted new filters.
The problem now is a loss of suction! In frustration I whacked the dust chamber (not sure of technical term) and the motor seemed to gain power and the suction sounded (and felt) much much better. Started to hoover and the motors sound changed and loss of suction again  >:( any ideas  :'(
Offline __russ__
« Reply #7 on: July 08, 2013, 11:50:25 pm »
The Zorbster is a bit different to the other DC04 models - the motor runs at two speeds, slow when the cyclone and bin are removed (supposedly to work Zorb powder into the carpet) and full speed when the cyclone and bin are attached again to use as a normal vacuum.
What I suspect is happening is that the bin isn't pressing the switch in properly that is located on the frame, just above the HEPA filter.
If you press it manually when the cyclone and bin is removed and this should change the motor speed.
The simple fix it to wedge something between the bin and switch to depress it whilst in use.
Offline absolutepurplelime
« Reply #8 on: August 10, 2013, 09:47:01 pm »
You should upload some pictures of it when you have finished it :) I love the DC04 :)
Offline bluetntmo
« Reply #9 on: August 10, 2013, 10:24:01 pm »
I have finished it ! Stuck some paper towel in the sensor switch and all cool apart from a noise when hoovering !
« Reply #10 on: November 15, 2013, 10:33:22 pm »
Rood!
« Reply #11 on: November 16, 2013, 04:46:18 pm »
Here is a Zorbster we did: https://manchestervacs.co.uk/DysonForum/index.php/topic,123.0.html
« Reply #12 on: November 17, 2013, 07:25:40 pm »
Thank you kindly mvacs, looks like it has just come out the factory :) :)
