You will find many gaps around the machine on the airflow system. You imagine they should be closed and tight, but they are not. They close up when the machine is in use.
If you can post a pic of the bit you think is wrong with your machine, that will help.
Is the ubend on at the bottom of the back hose? Number 8 on the diagrams.
