Dyson Models => First Generation "The Ball" Dysons. => Topic started by: DySenator on July 21, 2020, 03:56:58 am
Hello all,
I am trying to repair a DC25 as two different vacuum shops in my city of Ottawa, Canada has asked me to just replace the vacuum entirely. The suction is still great and apart from not switching from the wand to the motor, it works fine. The issue I have is while I was vacuuming one day, the wheel pin just fell off. From the diagrams on this site, it looks like the wheel spigot must have detached somehow. I've attached pictures of the wheel pin (with screw still in it).
Is this replaceable? If so, is the wheel spigot inside the changeover valve assembly or is it immediately behind the clear valve wheel? Any assistance would be greatly appreciated!
yes take side valve out just replace the back in the machine ,take wheel off as you have take valve out with flexi pipe ,just twist and push its easy ,tehre is a small part behing=d just replace and screw new one in done
Thank you very much! I'll provide an update as soon as I get my replacement wheel spigot!
