Dyson Models => Dyson DC01 (and DA 001) => Topic started by: Dyson2000 on June 21, 2015, 12:56:38 AM
Well i decided follow beko1987 and Madrat's suggestion. to give it a strip down and a good wash. i forgot to take pictures then i remembered half way though. it stank like old dogs and filthy. i thought it would be too late to take apart a hoover at 10:30pm. Im so impatient screw it take it apart and put it back together tomorrow ;D. i finished about midnight and i finished washing and drying it all. tomorrow i will post pictures me putting it all back together.
[attachimg=1]
[attachimg=2]
[attachimg=3]
[attachimg=4]
[attachimg=5]
[attachimg=6]
[attachimg=1]
[attachimg=2]
[attachimg=3]
[attachimg=4]
[attachimg=5]
all nice and clean. as i said i will leave it until tomorrow so its properly dried out before i reassemble it tomorrow.
[attachimg=6]
Nice job! It will look great when its done!
Bit of glue will sort that soleplate out!
Finished! what a pain in the back it was to put back together. its suction is really good how ever its gone louder :underchair: for some reason. i think the reason its loud because it can breath better. it needs filters and a new drive belt and tools but unfortunately. it turned out better than i thought
Motor Back in
[attachimg=1]
Cable Back on
[attachimg=2]
Getting There!
[attachimg=3]
Getting There!
Kickplate back on what a pain :angryman:
[attachimg=4]
Brush bar, Belt and Sole plate
[attachimg=5]
Thats so clean! Well done!
Finally Computer wasn't playing ball lol. anyway here is the final result! :grinn:
[attachimg=1]
[attachimg=2]
[attachimg=3]
[attachimg=4]
Photos out side ;D All my Dysons
[attachimg=1]
[attachimg=2]
[attachimg=3]
[attachimg=4]
[attachimg=5]
Glad i found this DC01. its sad to see it go to waste when there was nothing wrong with it :snivel:
That DC04 has the wrong cleaner head on it, although it doesn't look out of place......
The DC01 cleaned up well. :thumbsup:
Yeah I know. I wanted it to look different. If you look at my post about my Dc04 bin find and rebuild I think I explained about why I did that
The Dc01 looks lovely! (the one you found in the tip) Well done! ;D
That DC01 looks like new! If you want more suction, remove the 3 release valves on the cyclone (they pop out carefully from the outside), then, with a sharp stanley and some insulation tape, tape over the holes, cutting around the raised up mouldings, ensure it's tight down.
Improves things no end, just dont block it up obviously! Keep the release valves too, their quite tricky to get hold of...
I removed the Release valves on My DC01 Standard. the one i found in the tip. what a difference that made. the suction at the wand and the cleaner head. thanks for that :thumbsup: :thumbsup:
Its great isnt it! Amazing how much suction is lost, even with the seals cleaned to a spotless condition! Ive got loads spare now, cos I keep removing them!
Isn't it bad for the motor though when you sit it upright. It's pretty much choking it? And putting strain on the motor
Yea, it doesnt do it much good in the long term with prolonged blockage
But if you know it wont bleed the air, either start it reclined or eith the wand out, then dont mess about from getting the wand back in to reclining it.
My 01s dont see much use, its worth it for thrm to work better than they should for the brief time i use them!
I like mine that much I hoover the whole house with it a lot.
Good! Just dont leave it running blocked, as I'm sure you wouldnt anyway for more than a few seconds and youll be fine!
