Dyson Models => Dyson DC07 => Topic started by: Dysonboy on September 07, 2017, 07:14:31 pm
I heard that apprently you can boil a dc07 hepa filter and let it dry thouroughly to wash it? was thinking to check first before I boil a non-washable filter?
You will end up with a plastic ring and a lot of paper bits.
Thought it wouldn't work.
Gonna look at making a new post filter using an old hepa filter housing and old Dyson pre filter
Be careful, a sparking motor and polyurethane foam is a flammable mix.
Yeah I know - I refurbish dysons quite a bit
Yeah, sorry meant to add id be using the casing nothing else.
Thanks for the head up though, although I already knew that it might help someone else lol
I would never let a HEPA filter near water. Terrible combination, will only result in bad smells and reduced suction.
Interested to see results..
