Dyson Models => Dyson DC07 => Topic started by: Dysonboy123 on August 04, 2019, 03:12:36 pm
Can I wash the chassis? And if so, how long do I keep it soaked in the bath?
Yes. As long as you like.
I gwt the feeling that one is winding us up
within reason, EVERY part of a DC07 is washable except the electricals etc.
Everything plastic can be washed, best not to wash the metal rods within the brushroll or the wheel axel though, the wand/handle will be fine. Bearings are also a big no-no so remove them if you are going to bath the brush.
Power cable, switch, motor etc obviously cannot be washed.
Wand/handle, hose all give a good soak.
Do the side break or no?
Can you re-phrase the question?
I've seen them broken on all ages, be it due to brittle plastics or just being smashed.
Any help?
nothing wrong with it just carry on.
I made a dent in the bit which are circled. I was wondering if it's okay to use.
It's still useable, right?
Your questions are a little inane. If you don't grasp very basic science/physics, you probably shouldn't be taking stuff that connects to the mains apart.
