Dyson Models => Dyson DC04 => Topic started by: MalcyD on March 18, 2017, 06:15:46 pm
Title: Dyson DC04 very difficult to recline.
Post by: MalcyD on March 18, 2017, 06:15:46 pm
Hello all,
I've just replaced the motor and drive belt on my DC04 (none clutch model). As far as I can tell I've fitted everything back correctly and it works fine however, when trying to change from upright to reclined, it's very difficult and there's a loud 'crack' as the machine reclines. I've stripped it down again, apart from taking the motor out and I can't see anything causing any obstructions. Has anyone else had this problem and how do I fix it?
Thanks,
Mal.
Title: Re: Dyson DC04 very difficult to recline.
Post by: Madrat on March 18, 2017, 06:50:00 pm
Something is not aligned or fitted properly, can you post some pictures.
Post by: MalcyD on March 18, 2017, 07:12:17 pm
I could post pictures if I knew what to take pictures of.
Post by: Elgin on March 18, 2017, 08:40:42 pm
Pictures:
I'd say a picture of the bottom end of the chassis,
the inside of the head with the brushroll housing attached
changeover valve
and it all together if you can but not entirely nessasary
Post by: Madrat on March 18, 2017, 09:26:17 pm
both sides upright and reclined
Post by: MVacs on March 18, 2017, 11:59:36 pm
Look underneath, the issue may be >this part< (https://manchestervacs.co.uk/Dyson/DC04-DC07-DC14DC33-upright-lock-ass-908822-01).
Post by: MalcyD on March 19, 2017, 01:17:01 pm
Sorted. It was the 'upright lock' A squirt of WD40 and all is now good. Thanks everyone.
Post by: MVacs on March 20, 2017, 04:36:17 pm
We are good at this sort of thing.  8)
Post by: Elgin on March 29, 2017, 10:01:45 pm
If it were clutched i'd say to check the clutch cover, I had that issue on an Absolute, removed and reinstalled the cover and it was fine after.
