Dyson Models => Dyson DC01 (and DA 001) => Topic started by: beko1987 on November 19, 2014, 09:01:33 PM
Title: Dyson DA-001 - Stripdown and Refurb
Post by: beko1987 on November 19, 2014, 09:01:33 PM
Did this last week. HAve to say the plastics seemed more robust than the DC01!
When I got it, it was a bit meh
https://www.youtube.com/watch?v=s0bZcxT-5LI&list=UUv0y2E43HyJMX85p-Wxro0Q (https://www.youtube.com/watch?v=s0bZcxT-5LI&list=UUv0y2E43HyJMX85p-Wxro0Q)
Was a bit better with a new belt
https://www.youtube.com/watch?v=MxL3AYO5mxY&list=UUv0y2E43HyJMX85p-Wxro0Q (https://www.youtube.com/watch?v=MxL3AYO5mxY&list=UUv0y2E43HyJMX85p-Wxro0Q)
Started with the wand
(https://lh3.googleusercontent.com/-AaMHR0m_2GE/VGU-1OhhmzI/AAAAAAAAfe4/P-bGQdQ3j4c/s512/IMAG1921.jpg)
Release clip off
(https://lh4.googleusercontent.com/-i8Q98yZtVUI/VGU-zfI5TmI/AAAAAAAAfew/Fu42ZW4a76U/s800/IMAG1922.jpg)
Spring out
(https://lh3.googleusercontent.com/-BfLxqZtdBCE/VGU-xTvMpjI/AAAAAAAAfeo/Frhe6MW1NkQ/s512/IMAG1923.jpg)
Wand top is nicely unbroken
(https://lh5.googleusercontent.com/-uwjlaSWMlHQ/VGU-uI4T4AI/AAAAAAAAfeY/n3b8wsORcYY/s800/IMAG1925.jpg)
The collar on the end of the wand doesnt come off. I wasnt going to try either!
The two tools I found in the shed. Sadly not the original black ones though, but look the part and have a matching logo
(https://lh6.googleusercontent.com/-9GeH1W-a-Cg/VGU43HSo2vI/AAAAAAAAfd4/-Dw6tT7pkCs/s800/IMAG1927.jpg)
Onto the main cleaner now
(https://lh3.googleusercontent.com/-O43u98-bXNI/VGU41fEYJFI/AAAAAAAAfdw/ChNBPvK3FGQ/s512/IMAG1928.jpg)
Nice genuine filter
(https://lh4.googleusercontent.com/-8z9G71mYNE4/VGU4zqYwFxI/AAAAAAAAfdo/ss_8xiTjEhE/s800/IMAG1929.jpg)
Filter housing
(https://lh6.googleusercontent.com/-R0i6L0NTF-c/VGU4xvbS7eI/AAAAAAAAfdg/5vS1YV16soc/s800/IMAG1930.jpg)
(https://lh5.googleusercontent.com/-xYbcijs1t14/VGU4v47c1CI/AAAAAAAAfdY/Q62f4WRQ-z0/s800/IMAG1931.jpg)
(https://lh5.googleusercontent.com/-D7luX1t1PMg/VGU4uXa2m_I/AAAAAAAAfdQ/1UPiozLHBfY/s800/IMAG1932.jpg)
Cyclone seal off
(https://lh5.googleusercontent.com/-hK_lp-HrtoI/VGU4sfpGjUI/AAAAAAAAfdI/TRAFdwGdg38/s800/IMAG1933.jpg)
(https://lh3.googleusercontent.com/-TPyzaMHgXtY/VGU4rCTdM1I/AAAAAAAAfdA/B9g6NEZoNjw/s800/IMAG1934.jpg)
Wiring cover
(https://lh6.googleusercontent.com/-4mhWtb8zT3Q/VGU4pVs_JSI/AAAAAAAAfc4/2aLTZU9JdaU/s800/IMAG1935.jpg)
Yep, did that
(https://lh6.googleusercontent.com/-_rdSuafkqSw/VGU4n8uVJTI/AAAAAAAAfcw/zl_ErRhIpqk/s800/IMAG1936.jpg)
(https://lh3.googleusercontent.com/-HWCAQaA34YI/VGU4mV8AZ2I/AAAAAAAAfco/okbtBFv1rmQ/s800/IMAG1937.jpg)
Cord clamps
(https://lh4.googleusercontent.com/-m3jENDxAmA8/VGU4k4U_EUI/AAAAAAAAfcg/huS1Aw34KdQ/s800/IMAG1938.jpg)
(https://lh5.googleusercontent.com/-BbFVVetIsOw/VGU4jeCmwUI/AAAAAAAAfcY/z0JZbPXjdTo/s800/IMAG1939.jpg)
Someone's been here before...
(https://lh6.googleusercontent.com/-5EYdqVtPI3I/VGU4h-fNwlI/AAAAAAAAfcQ/-mX8LEpS1tM/s800/IMAG1940.jpg)
Cable out of the way
(https://lh3.googleusercontent.com/-9rvdC5j0miI/VGU4gdOg7zI/AAAAAAAAfcI/-nXgn7AqIOY/s512/IMAG1941.jpg)
I've never known how to get the switch out of a DC01, wasnt about to try here!
(https://lh5.googleusercontent.com/-UW1u47J1p_o/VGU4enXRbwI/AAAAAAAAfcA/EyPMkfazc2g/s512/IMAG1942.jpg)
Eva decided she wanted to fix her dyson...
(https://lh6.googleusercontent.com/-ra-DicZcQtw/VGU4dATAftI/AAAAAAAAfb4/djHafnfpBgw/s800/IMAG1943.jpg)
Spine cord out of the top
(https://lh3.googleusercontent.com/-ERmzhiCVWeQ/VGU4bC3xCyI/AAAAAAAAfbw/qQVw0iXYE9M/s512/IMAG1944.jpg)
Side filter housing out (was choked when I bought it, binned it there and then)
(https://lh5.googleusercontent.com/-H94g8JmCJ1M/VGU4Zd-GI6I/AAAAAAAAfbo/zuXuSkQDamQ/s800/IMAG1945.jpg)
Upside down now
(https://lh4.googleusercontent.com/-ugUND0ZHSJw/VGU4XRnBKtI/AAAAAAAAfbg/NajrC7AUKDA/s800/IMAG1946.jpg)
(https://lh5.googleusercontent.com/-amIQTBNNdcQ/VGU4VqcxYII/AAAAAAAAfbY/8ilftmkPEsE/s800/IMAG1947.jpg)
The only bit of damage on the soleplate
(https://lh5.googleusercontent.com/-w_GRmKE2_ps/VGU4TtC5WUI/AAAAAAAAfbQ/taXTgcuvC48/s512/IMAG1948.jpg)
Not too grubby
(https://lh6.googleusercontent.com/-OjYzg9taxYc/VGU4RwBBexI/AAAAAAAAfbI/wh2mbBuFJIU/s800/IMAG1949.jpg)
Soleplate seal out
(https://lh4.googleusercontent.com/-c_KmWO-99M8/VGU4QWLNWUI/AAAAAAAAfbA/xXfs9i_Bvs8/s800/IMAG1950.jpg)
(https://lh6.googleusercontent.com/-Wnilip2ixCE/VGU4OXp7K7I/AAAAAAAAfa4/a_G0WYAfwTI/s800/IMAG1951.jpg)
Brushroll stripped down
(https://lh5.googleusercontent.com/-Jtu7-j8lXbU/VGU4MfyCmbI/AAAAAAAAfaw/MInxHVrsE1g/s800/IMAG1952.jpg)
End caps
(https://lh3.googleusercontent.com/-yt2Lw74TMa0/VGU4KfIIvCI/AAAAAAAAfao/uXb1lByAKmA/s800/IMAG1953.jpg)
Brushroll is a bit soft, but in good order and not too worn
(https://lh4.googleusercontent.com/-kLthLb1axTQ/VGU4IZelV5I/AAAAAAAAf3I/_AaO8GbgyOc/s800/IMAG1954.jpg)
Bumper off
(https://lh6.googleusercontent.com/-3JSnlppfmCU/VGU4GV3zZTI/AAAAAAAAfaY/-OgNay7DxPg/s800/IMAG1955.jpg)
Brushroll housing off
(https://lh5.googleusercontent.com/-6tu2y8PH3Rg/VGU4ElqJ_5I/AAAAAAAAfaQ/OmWdQ7ZRN14/s512/IMAG1956.jpg)
(https://lh4.googleusercontent.com/-hWLU7T6-qQA/VGU4Cx6zB3I/AAAAAAAAfaI/UjbpNtv52Yw/s800/IMAG1957.jpg)
The clip that keeps it upright. It never worked very well, a slight bend has helped it alot!
A date stamp
(https://lh6.googleusercontent.com/-lsKH0xWAykc/VGU3_ROb2jI/AAAAAAAAfZ4/mVhRwJFcPnM/s800/IMAG1959.jpg)
Never seen this style of circlip before
(https://lh4.googleusercontent.com/-Jcfncf0mO1s/VGU39iloDoI/AAAAAAAAf3Q/xQgdII4BDnE/s800/IMAG1960.jpg)
(https://lh4.googleusercontent.com/-uiYz5l8ACAA/VGU37xcn8xI/AAAAAAAAf3Y/c2SknD1R0UE/s800/IMAG1961.jpg)
One wheel has a bit of damage though sadly
(https://lh5.googleusercontent.com/-Fnhsu9h3eJA/VGU36YfO_4I/AAAAAAAAfZg/hLl2bOglMig/s800/IMAG1962.jpg)
Motor housing now
(https://lh3.googleusercontent.com/-P86gG95Jyiw/VGU34mxfT4I/AAAAAAAAfZY/UJFGv-hVFQc/s800/IMAG1963.jpg)
Which is held together with phillips screws. Took a few minutes with the t25 before getting a torch to figure that out...
(https://lh6.googleusercontent.com/-5k3zWEsIJtU/VGU3286dOiI/AAAAAAAAfZQ/dx70qyhY3Cw/s512/IMAG1964.jpg)
(https://lh5.googleusercontent.com/-zNCjTPTxlSs/VGU31VJWiGI/AAAAAAAAfZI/HjKutOl8jHY/s800/IMAG1965.jpg)
(https://lh5.googleusercontent.com/-z8uMM0yuZPQ/VGU3zZgGolI/AAAAAAAAfZA/cnq7zrzrfhc/s800/IMAG1966.jpg)
Not black with carbon which is nice to see
(https://lh6.googleusercontent.com/-S-26XGlCcFY/VGU3xn4e6qI/AAAAAAAAf3g/G4PuKQjDBEs/s800/IMAG1967.jpg)
(https://lh4.googleusercontent.com/-Ax2VIRnQras/VGU3wHR-WZI/AAAAAAAAfYw/47mHqmcwQQs/s800/IMAG1968.jpg)
Bottom flaps out
(https://lh6.googleusercontent.com/-4x-AvaTr_c8/VGU3uaHDkyI/AAAAAAAAf3o/wB5gDnlORIU/s800/IMAG1969.jpg)
(https://lh3.googleusercontent.com/-n9iidQ7Jua8/VGU3sgzfH3I/AAAAAAAAfYg/Bi02EYL_uXY/s800/IMAG1970.jpg)
Wiring next
(https://lh6.googleusercontent.com/-qo_MQu3fKl8/VGU3rDbMTnI/AAAAAAAAfYY/D7PC5OCjwm4/s800/IMAG1971.jpg)
Dyson used to make small components too!
(https://lh3.googleusercontent.com/-LguMymy1ws8/VGU3pakIp-I/AAAAAAAAfYQ/KUvc9qQcS3o/s800/IMAG1972.jpg)
Motor out
(https://lh4.googleusercontent.com/-gink_ZotrxY/VGU3n19T8OI/AAAAAAAAfYI/0-I0cei5kfE/s800/IMAG1973.jpg)
Sorry for the flash flare
(https://lh3.googleusercontent.com/-eT9Tg98BeHA/VGU3lnpP4iI/AAAAAAAAfYA/_YgaRruWSUQ/s800/IMAG1974.jpg)
Clean looking armature
(https://lh3.googleusercontent.com/-ICBB8z-6oWw/VGU3jZ94u7I/AAAAAAAAfX4/PvxK6-NM1_0/s800/IMAG1975.jpg)
(https://lh5.googleusercontent.com/-AsrTX4AGVcs/VGU3huNRdZI/AAAAAAAAfXw/b-gq7-1AbW8/s800/IMAG1976.jpg)
(https://lh3.googleusercontent.com/-255g04Fp0cc/VGU3f5xmQNI/AAAAAAAAfXo/W6UJCNyRyn0/s800/IMAG1977.jpg)
All but one screw holding the motor housing onto the airflow duct were torx, one was phillips...
(https://lh6.googleusercontent.com/-ZFGliLunTyc/VGU3eIF4vII/AAAAAAAAfXg/PTAlR5c_XD8/s800/IMAG1978.jpg)
(https://lh5.googleusercontent.com/-tif5gmeRRac/VGU3clyNYvI/AAAAAAAAfXY/hfZAFg3Z9Zo/s800/IMAG1979.jpg)
Not too dirty
(https://lh4.googleusercontent.com/-9-db7RRaD1Y/VGU3anBoe3I/AAAAAAAAfXQ/Zdj9ISmZPaw/s800/IMAG1980.jpg)
(https://lh4.googleusercontent.com/-Q_HhoGy6vc8/VGU3Y3D_-eI/AAAAAAAAfXI/YPRM7_eFuh0/s800/IMAG1981.jpg)
(https://lh3.googleusercontent.com/-yGxN81rbIR0/VGU3XGlN7-I/AAAAAAAAf3w/g5B2BQRL7ZQ/s800/IMAG1982.jpg)
Little valve so the suction has somewhere to go when the wands in
(https://lh5.googleusercontent.com/-S0E2BA90Ius/VGU3VNZbY9I/AAAAAAAAfW4/qkaN1gNUslE/s800/IMAG1983.jpg)
(https://lh3.googleusercontent.com/-yyaWMsG3frU/VGU3TeVwYPI/AAAAAAAAf34/orJ-UGbo2n0/s800/IMAG1984.jpg)
Getting there
(https://lh5.googleusercontent.com/-KxdbbUbdXck/VGU3R0jQ-PI/AAAAAAAAfWo/XMvDJHTC4QI/s800/IMAG1985.jpg)
(https://lh6.googleusercontent.com/-rCFo24Xoqy8/VGU3QMpUQGI/AAAAAAAAfWg/drejvXwe_Xw/s800/IMAG1986.jpg)
(https://lh3.googleusercontent.com/-TZSG7PYewQ4/VGU3OTMYvzI/AAAAAAAAfWY/Be-AlVYipIE/s800/IMAG1987.jpg)
(https://lh6.googleusercontent.com/-DDgAeufJiEU/VGU3MxRlscI/AAAAAAAAfWQ/8irAmGyk5jI/s800/IMAG1988.jpg)
More seals out
(https://lh4.googleusercontent.com/-9LvP0zsutDg/VGU3Kx1rGaI/AAAAAAAAfWI/1SrSUDLyq8E/s800/IMAG1989.jpg)
(https://lh3.googleusercontent.com/-G5cKT2Q7dJg/VGU3JPyNCsI/AAAAAAAAf4A/j0ZN5ip5yVY/s800/IMAG1990.jpg)
Cyclone now
(https://lh4.googleusercontent.com/-PR_4fpx0UBk/VGU3HUb9LLI/AAAAAAAAfV4/F7GZ-LMdT40/s512/IMAG1991.jpg)
(https://lh5.googleusercontent.com/-TBn0myTMOM4/VGU3FlZdwyI/AAAAAAAAfVw/hu719jsa31M/s800/IMAG1992.jpg)
I got excited about these stickers until I remembered the cone came from a DeStijl...
(https://lh4.googleusercontent.com/-uVXY2TrXX9s/VGU3DzPbntI/AAAAAAAAfVo/zy0VFb07ayE/s800/IMAG1993.jpg)
Managed to break one of the release valves too sadly
(https://lh5.googleusercontent.com/-mmTJHcCUhgE/VGU3B-Nc4gI/AAAAAAAAfVg/MKwLVR_luKQ/s800/IMAG1994.jpg)
Split
(https://lh6.googleusercontent.com/-aRKFPTOvDlc/VGU3AT1vqLI/AAAAAAAAfVY/-HHOWgyglRg/s800/IMAG1995.jpg)
Everything was then washed, and given a first stage polish with cif, then Farcela Paint Renovator to put some shine back on
And an exploded diagram
(https://lh3.googleusercontent.com/-ibgG6xUvQbU/VGam8xKtsXI/AAAAAAAAfkE/0C-FMm3ii9c/s512/IMAG2021.jpg)
(https://lh5.googleusercontent.com/-yzHCo2yq4dQ/VGam7WplIBI/AAAAAAAAfj8/4NkVy_ek6B8/s800/IMAG2022.jpg)
(https://lh5.googleusercontent.com/-zsRXu6KstrI/VGam5Tyx4PI/AAAAAAAAfj0/TN9vY9jVzv8/s512/IMAG2023.jpg)
Spine cable (which was very difficult as the hole is the same size as the cable, rather than having a bigger hole in the dc01) and seals back on
(https://lh4.googleusercontent.com/-Dh7rAfUXSv8/VGam3mKvEDI/AAAAAAAAfjs/aX9sNORbNMo/s800/IMAG2024.jpg)
(https://lh3.googleusercontent.com/-T7cXfw4LHvs/VGam1rfmP9I/AAAAAAAAfjk/H3meIA0EeFU/s800/IMAG2025.jpg)
Noticed this repair on the bottom seal, I elected to leave it alone!
(https://lh5.googleusercontent.com/-Cp9HH_lg0R8/VGam0NgiubI/AAAAAAAAfjc/Vh_T-WbYS_0/s800/IMAG2026.jpg)
(https://lh6.googleusercontent.com/-e9aQ1oJ5_Xs/VGamytshQJI/AAAAAAAAfjU/yAagGzjm4Lg/s800/IMAG2027.jpg)
Motor back in
(https://lh6.googleusercontent.com/-EJ0udmCPCgc/VGamw7WoiaI/AAAAAAAAfjM/ONRoF9Y4szE/s800/IMAG2028.jpg)
Seals back in the motor housing
(https://lh3.googleusercontent.com/-JX2hTUuA9iE/VGamvAwAstI/AAAAAAAAfjE/LcgHuuFRonc/s800/IMAG2029.jpg)
(https://lh4.googleusercontent.com/-ykVYgz2bcro/VGamtVBM2cI/AAAAAAAAfi8/7ozYpplrXro/s512/IMAG2030.jpg)
Wheels back on
(https://lh4.googleusercontent.com/-eh_PaSXAsOY/VGamrioncKI/AAAAAAAAfi0/yUp5dgDuOWo/s800/IMAG2031.jpg)
Some wheel caps kindly donated by a Dyson collector! (cheers George!)
(https://lh3.googleusercontent.com/-mZIrLdnGr-g/VGamqFqQZoI/AAAAAAAAfis/JrVT7ZWhkMw/s800/IMAG2032.jpg)
Cleaner head back on
(https://lh5.googleusercontent.com/-n89LvmEDEDE/VGamohu4UpI/AAAAAAAAfik/aA5T1rHAUjY/s512/IMAG2033.jpg)
Bumper back on
(https://lh4.googleusercontent.com/-5MPZkHwwsaY/VGammp_D2FI/AAAAAAAAfic/i3pZcNvXshM/s800/IMAG2034.jpg)
Grabbed the brushroll bits
(https://lh6.googleusercontent.com/-On34NyzbfZY/VGamk7vs8wI/AAAAAAAAfiU/DaxWUCk98qk/s800/IMAG2035.jpg)
back in
(https://lh4.googleusercontent.com/-bpLvWRLKbRg/VGamjOk9OYI/AAAAAAAAfiM/a3ATZioQQE8/s800/IMAG2036.jpg)
Baseplate was in very good condition underneath the muck
(https://lh6.googleusercontent.com/-D6h-zdhFOhI/VGamhmVp9UI/AAAAAAAAfiE/gYCwOgVeIHk/s800/IMAG2037.jpg)
New pre motor filter
(https://lh5.googleusercontent.com/-OAPP5LtJ-zY/VGamfqrASvI/AAAAAAAAfh8/hChQRC9un8M/s800/IMAG2038.jpg)
(https://lh5.googleusercontent.com/-g7xassfqH3E/VGamd9yfvyI/AAAAAAAAfh0/wTlS3I8hdbw/s800/IMAG2039.jpg)
And new post motor filter
(https://lh3.googleusercontent.com/-MIsK1LRHRZE/VGamcKhUG0I/AAAAAAAAfhs/VP3Va4QpQes/s800/IMAG2040.jpg)
(https://lh4.googleusercontent.com/-Qz29WUWovTQ/VGamaq3HJgI/AAAAAAAAfhg/_8zgUAnGXLc/s512/IMAG2041.jpg)
Cyclone back together now
(https://lh6.googleusercontent.com/-JJ_LgXeYoew/VGamY5DY7aI/AAAAAAAAfhY/Mt4wMhFNoro/s512/IMAG2042.jpg)
(https://lh5.googleusercontent.com/-Wo6M2zoeDnA/VGamXaplT3I/AAAAAAAAfhQ/C_e09PD_hWI/s800/IMAG2043.jpg)
(https://lh4.googleusercontent.com/-JCDj2zeVjRk/VGamVVPYtsI/AAAAAAAAfhI/orF9f6rL_SQ/s800/IMAG2044.jpg)
(https://lh6.googleusercontent.com/-hCBqrqSABR4/VGamTnm59UI/AAAAAAAAfhA/4A2HXzKdYsA/s512/IMAG2045.jpg)
Wiring back in
(https://lh5.googleusercontent.com/-aJtfwy71yG8/VGamRz8ngrI/AAAAAAAAfg4/IOdTlA5Mqio/s800/IMAG2046.jpg)
Release valves in, pinched one from my spares destijl, its made of a different type of plastic, different colour too!
(https://lh3.googleusercontent.com/-gBr_Sq8hpoE/VGamQNaIPBI/AAAAAAAAf4Y/D5MPGts5Rfc/s800/IMAG2047.jpg)
Cleaned the plug up too
(https://lh5.googleusercontent.com/-BJDd9w2Jow4/VGamOVd1CBI/AAAAAAAAfgo/INEK-J3oJBM/s512/IMAG2048.jpg)
and refitted the hose and wand
(https://lh5.googleusercontent.com/-dvf4ugY-WYk/VGamM1uXINI/AAAAAAAAfgg/R2_zr8bF9xQ/s512/IMAG2050.jpg)
And she's done! Needs a final polish, and the top cyclone handle sticker rubbed off a bit during washing, but I have a plan for that...
(https://lh6.googleusercontent.com/-FioNz0ol-SQ/VGamLPzbjdI/AAAAAAAAfgY/7IUCWxmxJHw/s512/IMAG2051.jpg)
(https://lh6.googleusercontent.com/-tFas8edo7gg/VGamJcVSKUI/AAAAAAAAfgQ/9DRRDD8H_DE/s800/IMAG2052.jpg)
(https://lh6.googleusercontent.com/-5D--kIlWncg/VGamH4DkE5I/AAAAAAAAfgI/qGH3Wej48_s/s512/IMAG2053.jpg)
https://www.youtube.com/watch?v=Ckpv7TO-N04&list=UUv0y2E43HyJMX85p-Wxro0Q (https://www.youtube.com/watch?v=Ckpv7TO-N04&list=UUv0y2E43HyJMX85p-Wxro0Q)
Next to a DC14 I'm selling
(https://lh3.googleusercontent.com/-dUg_SgXhCuE/VGamGGK4d_I/AAAAAAAAfgA/byWqlNPGDck/s512/IMAG2055.jpg)
(https://lh6.googleusercontent.com/-0kjqfR43M68/VGamES_W8MI/AAAAAAAAff4/VRnSCbYP6GE/s512/IMAG2054.jpg)
Been using it a bit since, it does glue itself to the carpet now, performs VERY well. Am very pleased to have added it to the collection!
(https://lh6.googleusercontent.com/-BmiWs-_UkMA/VG0E1Y83PDI/AAAAAAAAf4k/kanLu5zhKtM/s512/IMAG2225.jpg)
Title: Re: Dyson DA-001 - Stripdown and Refurb
Post by: MVacs on November 20, 2014, 09:15:11 AM
Nice job on what is now a quite rare machine.  :thumbsup:
Post by: beko1987 on November 24, 2014, 07:04:48 PM
Thanks! I used it all last week and tbh it has better suction than my DC01 De Stijl, which is nice. I ran the polisher over it last night and tbh it made no difference so I emptied the cyclone, cleaned it up and put it back to the fresh look and it's now sat in the Loft as I needed to make room for other projects!
Did buy something for it yesterday though, will update when that turns up...
