Dyson Models => Handheld, Cordless, Stick, Wand & Robotic Dyson Vacuum Cleaners => Topic started by: Parwaz7862 on January 17, 2017, 07:00:25 pm
So I believe the runtime is 20 mins (on normal mode) and 17 mins with a motorised head and then 8 mins on max.
Mine? It got a runtime of about 12 mins on normal mode and 5 secs on max!
Now, mine is the later model because the battery is held in by 2 screws rather than a button
Do you reckon it needs a new battery or motor unit? It has no safety switch for the filter BTW
Thanks ;)
Battery
Battery
Yep. They are not much cop.
However, check both outputs on the charger first.
Cheers both
The charger seems to work just like my DC30/34/35 ones I had in the past and the light goes off after a few hours so I presume (going by that) it works flawlessly
Will try a new battery tho thanks :thumbsup:
That's a point, make sure both outputs are working from charger.
Dont assume, test both outputs. If one is down it won't charge fully.
Good point
I'll check that
