Dyson Models => Dyson DC07 => Topic started by: Dysonboy123 on July 21, 2021, 07:16:22 PM
Title: Forward lock problem... again!
Post by: Dysonboy123 on July 21, 2021, 07:16:22 PM
I have a dc07 which it's forward lock keeps going out of place. Any ideas?
Title: Re: Forward lock problem... again!
Post by: dysondestijl on July 22, 2021, 10:26:59 PM
The lock hinges on the cleaner head are most likely warped or broken. Have you got another head you can try on it?
Post by: Dysonboy123 on July 23, 2021, 07:28:08 AM
It's not the one on the cleaner head, it's this one.
[attachimg=1]
Post by: bluebumble485 on July 24, 2021, 02:19:32 PM
take out put in hot water then pull the tabs out gently and hold .it takes a bit they will clip in then
Post by: Dysonboy123 on August 28, 2021, 06:55:24 PM
How long do you leave it in for?
Post by: Dysonboy123 on August 30, 2021, 02:15:59 PM
Forward lock keeps coming out of place after reassembling it.  :angryman:
Post by: MVacs on August 30, 2021, 11:16:37 PM
Probably 30 seconds in boiling water will make it pliable.
Post by: Dysonboy123 on August 31, 2021, 11:52:59 AM
I did that and fitted it back but keeps coming out of place.
Post by: dysondestijl on August 31, 2021, 11:00:10 PM
I can only assume the tabs havenít been bent back enough. Unless itís damaged or the casing itís in is damaged, and only you can tell that, not us!
Post by: Dysonboy123 on September 01, 2021, 07:55:27 AM
I did check it and it doesn't look damaged to me.
Post by: Dysonboy123 on September 01, 2021, 10:25:06 AM
I fitted it and it works but when I put the cleaner head back on it goes out of place.
