Dyson Models => First Generation "The Ball" Dysons. => Topic started by: Rab1127 on May 25, 2013, 12:03:36 am
I am trying to replace the brush bar motor cover on my DC15. I believe that I need to disconnect the yoke loom assy from the PCB loom assy to be able to thread the yoke loom through the hole in the motor cover.
There is a black and a white wire connecting to two black coated wires with red ends. Each connection is covered by a small plastic cover. I think I just need to pull them apart, but they appear to be stuck.
Am I on the right track and just need to carefully put a little more effort into it? Is there somewhere else to disconnect the yoke loom so it can thread through?
