Dyson Models => Dyson DC07 => Topic started by: beko1987 on March 03, 2014, 09:40:20 pm
Picked a funky looking vac out of my recent haul and decided to do a thread!
(https://lh6.googleusercontent.com/-5iWt9qQ8WiE/UxTsyMXxG4I/AAAAAAAAU_k/fazb2LfnINU/s512/IMAG0170.jpg)
(https://lh6.googleusercontent.com/-w2gGw9WL-UM/UxTszthnypI/AAAAAAAAU_s/z94YZSIFcCI/s512/IMAG0171.jpg)
Had all its tools too
(https://lh5.googleusercontent.com/-9sX4EfGTCuI/UxTs1QzDEmI/AAAAAAAAU_0/s4zf9S5ug1M/s512/IMAG0172.jpg)
They were first into the washing box
(https://lh5.googleusercontent.com/-8XQhpjX7VgA/UxTs3PcAvII/AAAAAAAAU_8/qirD8SyFPDA/s800/IMAG0173.jpg)
The hose was like new
(https://lh5.googleusercontent.com/-0F7Cwq5lPpw/UxTs5Z8bJRI/AAAAAAAAVAE/wv7TA_JUSV4/s800/IMAG0174.jpg)
Then I worked out why, pattern hose. Meh, works well enough!
(https://lh4.googleusercontent.com/-7eMyNZFhdsw/UxTs7mQltII/AAAAAAAAVAM/djaFRBRPJMk/s800/IMAG0175.jpg)
Stripped the wand as much as I usually do
(https://lh4.googleusercontent.com/-lrDbQCYiYOk/UxTs9A-T00I/AAAAAAAAVAU/0ZvFVaF495U/s800/IMAG0176.jpg)
Switch housing off
(https://lh4.googleusercontent.com/-3dhyKHxRW9Y/UxTs_6wkJoI/AAAAAAAAVIE/3l042PB4Zo0/s800/IMAG0177.jpg)
Switch and wiring
(https://lh3.googleusercontent.com/-05mHjvtrHxk/UxTtBX2xwQI/AAAAAAAAVAk/Bd-qDRziMfc/s800/IMAG0178.jpg)
Switch out
(https://lh6.googleusercontent.com/-Qf-3MC-Obw8/UxTtDMAxZ6I/AAAAAAAAVAs/54BcAGAHbHY/s800/IMAG0179.jpg)
Top end empty
(https://lh5.googleusercontent.com/-_WzeJJpvTR4/UxTtExdV2CI/AAAAAAAAVA0/Wa3UXTnb9Qg/s800/IMAG0180.jpg)
(https://lh6.googleusercontent.com/-uaWlN9MeKPE/UxTtGoCDVCI/AAAAAAAAVA8/_yPHwF_Zg5E/s800/IMAG0181.jpg)
(https://lh6.googleusercontent.com/-HT2EfIklcKc/UxTtIHyNQ0I/AAAAAAAAVBE/_p65aJQ_XBk/s800/IMAG0182.jpg)
Post motor filter
(https://lh5.googleusercontent.com/-Ogo3njeAxlE/UxTtLZ1vo1I/AAAAAAAAVBM/K-8DhF3xM_M/s800/IMAG0183.jpg)
Bit of flash flare but that went in the bin
(https://lh4.googleusercontent.com/-CF4ptDWEx0E/UxTtNXguK_I/AAAAAAAAVBU/JC0fNceAmso/s800/IMAG0184.jpg)
(https://lh6.googleusercontent.com/-NhFl2Movr9Y/UxTtPWSsiUI/AAAAAAAAVBc/7zqiYandL0Q/s800/IMAG0185.jpg)
Elbow next
(https://lh5.googleusercontent.com/-PyvlkWsIEiA/UxTtRaqj24I/AAAAAAAAVBk/6QRDwuXBa8E/s800/IMAG0186.jpg)
(https://lh3.googleusercontent.com/-C6i4lIEpF7M/UxTtTeOl6pI/AAAAAAAAVBs/w-FUYAcAMe4/s800/IMAG0187.jpg)
Pre motor filter
(https://lh6.googleusercontent.com/-1nF3AMPOXoM/UxTtVEo1nEI/AAAAAAAAVB0/C2Z2eorxUZ0/s800/IMAG0188.jpg)
(https://lh5.googleusercontent.com/-prXnJbdmRms/UxTtX-l14cI/AAAAAAAAVIM/Yb4RWUBjx48/s800/IMAG0189.jpg)
Whip this seal off
(https://lh5.googleusercontent.com/-3zDbFyMctr4/UxTtZSTv8CI/AAAAAAAAVCE/5_Ijlfllw_o/s800/IMAG0190.jpg)
Strip the release valve down
(https://lh3.googleusercontent.com/-PNljsOVsL74/UxTtexCvUDI/AAAAAAAAVIU/C22_Jla0Cp4/s800/IMAG0192.jpg)
And wheels off
(https://lh4.googleusercontent.com/-cTri9E5L-HU/UxTtg6jAFoI/AAAAAAAAVCc/VPe5ZSvunUE/s800/IMAG0193.jpg)
U bend out and Ah!
(https://lh3.googleusercontent.com/-nZOK7dkCvRM/UxTtkq84jvI/AAAAAAAAVCk/AlzGb-YnQPE/s800/IMAG0194.jpg)
Green thing is a plastic whatever
(https://lh5.googleusercontent.com/-EvTFLlbexTI/UxTtm0GJkjI/AAAAAAAAVCs/6JlGQ9KiY4g/s800/IMAG0195.jpg)
Time to flip it over and work from the bottom up (I haven't actually seen under this yet, I just know it runs and the brushroll turns...)
(https://lh6.googleusercontent.com/-JDixV397FL8/UxTtbdm81CI/AAAAAAAAVCM/TvKbNR_iiWc/s800/IMAG0191.jpg)
Baseplate out
(https://lh5.googleusercontent.com/-GfxIm6VFcmQ/UxTto6IRSII/AAAAAAAAVC0/RboZx1QKcUo/s800/IMAG0196.jpg)
Baseplate stripped
(https://lh4.googleusercontent.com/-uSS7zdY6S_A/UxTtq-2Y6BI/AAAAAAAAVC8/OICkhRHghmw/s800/IMAG0197.jpg)
Belts were so worn I could lift this out with ease without the lifter tool
(https://lh4.googleusercontent.com/-gIi9b0v7LLE/UxTttSEeXdI/AAAAAAAAVDE/G3l9cn2-q4A/s800/IMAG0198.jpg)
I grabbed stanley and got cutting
(https://lh6.googleusercontent.com/-pyJcfAHe_eA/UxTtvSVAqpI/AAAAAAAAVDM/ZD3kewmzZFk/s800/IMAG0199.jpg)
Quick going over of the bristles with my little wire brush and good as new!
(https://lh5.googleusercontent.com/-ou57NM42SWY/UxTtx_iZCXI/AAAAAAAAVDU/BwEo_YQZTwo/s800/IMAG0200.jpg)
Bearings out
(https://lh6.googleusercontent.com/-Ki0iYBiXeXE/UxTt0ZtURUI/AAAAAAAAVDc/AiyBtwhAVeY/s800/IMAG0201.jpg)
Brushroll carrier out
(https://lh3.googleusercontent.com/-tsNzAdweD5o/UxTt4e7VgSI/AAAAAAAAVDk/OVIQIXuOt_w/s800/IMAG0202.jpg)
I imagine the brushroll and clog stopped this getting used very much, hence why its quite clean
Clutch cap off
(https://lh5.googleusercontent.com/-P9qpLDtd_zk/UxTt6zU12XI/AAAAAAAAVDs/PAirWMrcYi4/s800/IMAG0203.jpg)
Clutch cover off
(https://lh4.googleusercontent.com/-lx8-_oMd1SE/UxTt98RsTHI/AAAAAAAAVD0/MYPUetpwrHk/s800/IMAG0204.jpg)
I presume this date wont match the build date of the machine? Still, scary to think this is 11 years old now!
(https://lh5.googleusercontent.com/-3v1hTI0rZuM/UxTuAcm3otI/AAAAAAAAVIg/HjfUtnW_gZE/s800/IMAG0205.jpg)
(https://lh3.googleusercontent.com/-H4uN-YoHYoA/UxTuCCD2Q_I/AAAAAAAAVEE/fPLNMAEISGo/s800/IMAG0206.jpg)
Pop the circlips off
(https://lh4.googleusercontent.com/-yutGKroTUI8/UxTuEQT2dCI/AAAAAAAAVEM/S3vUrnc1m6M/s800/IMAG0207.jpg)
And off with its head
(https://lh5.googleusercontent.com/-GCRQd6DfmhM/UxTuGqVWfVI/AAAAAAAAVEU/SZHMToa5o1U/s800/IMAG0208.jpg)
(https://lh6.googleusercontent.com/-4D_jlAEzvRE/UxTuIvNT6oI/AAAAAAAAVEc/8dg486TcwSA/s800/IMAG0209.jpg)
Locking tab out
(https://lh6.googleusercontent.com/-lQ8c6f473fw/UxTuKJjpLGI/AAAAAAAAVEk/AAe-rD8ZVKc/s800/IMAG0210.jpg)
(https://lh4.googleusercontent.com/-WcYRNgwpf2A/UxTuMBPfXqI/AAAAAAAAVIo/sV0ypJ1MihA/s800/IMAG0211.jpg)
Seal off
(https://lh4.googleusercontent.com/-62olVHZMHmk/UxTuOCPHQoI/AAAAAAAAVE0/-zxcAyEIc9s/s800/IMAG0212.jpg)
(https://lh6.googleusercontent.com/-tqQQv8ntYGg/UxTuQCWdx9I/AAAAAAAAVE8/1sBKBUsq1kc/s800/IMAG0213.jpg)
(https://lh6.googleusercontent.com/-LUWrStQQXlE/UxTuSUncfpI/AAAAAAAAVFE/wB-tJw1KODk/s800/IMAG0214.jpg)
and Diverter valve out
(https://lh3.googleusercontent.com/-tNOJGk_S9gY/UxTuUayhfBI/AAAAAAAAVFM/n9vqQJqxSTg/s800/IMAG0215.jpg)
Airway cover out
(https://lh6.googleusercontent.com/-n5lQ2EI8mfg/UxTuWEg9LyI/AAAAAAAAVFU/Hg_HZ3YQHMI/s800/IMAG0216.jpg)
4 Motor cover screws and out comes the throbbing heart of the beast...
(https://lh5.googleusercontent.com/-mgIcglaqxV8/UxTuX2ut2QI/AAAAAAAAVFc/va_0gjI2SZg/s800/IMAG0217.jpg)
(https://lh3.googleusercontent.com/-jdyw4XmAt78/UxTua-p_BzI/AAAAAAAAVFk/EgZaxB5FfCg/s800/IMAG0218.jpg)
(https://lh3.googleusercontent.com/-JUwvEJ-l1FA/UxTucspgo_I/AAAAAAAAVFs/PooqccxVQwM/s800/IMAG0219.jpg)
(https://lh6.googleusercontent.com/-mx2vc2SBBk0/UxTuesTbikI/AAAAAAAAVF0/r_rnn0IIEmQ/s800/IMAG0220.jpg)
Will run some brake cleaner over the motor later to clean it up a bit. It runs perfectly fine, is even smoother after a drop of 3 in 1 on the top bearing
Pre motor filter elbow off
(https://lh4.googleusercontent.com/-0bUnp6DFP-w/UxTugCajw4I/AAAAAAAAVF8/lU__Wq98alY/s800/IMAG0221.jpg)
And one chassis!
(https://lh6.googleusercontent.com/-7PZXa02eZks/UxTuhrdbuJI/AAAAAAAAVGE/16a3FYLqsxI/s512/IMAG0222.jpg)
Cyclone next
(https://lh5.googleusercontent.com/-7WRr-KJuSXY/UxTujQ67vuI/AAAAAAAAVGM/CSbGsqORHnk/s512/IMAG0223.jpg)
(https://lh4.googleusercontent.com/-wM_GKSFesZo/UxTulCtjTHI/AAAAAAAAVGU/RV9S98syhu8/s800/IMAG0224.jpg)
Scraped the crusty bits off, dont want to clog the plughole when washing it!
(https://lh5.googleusercontent.com/-egbICQdgfqU/UxTumu8CXdI/AAAAAAAAVGc/csL6dB5G6XU/s800/IMAG0225.jpg)
Top screws out
(https://lh3.googleusercontent.com/-nfA1YrqbIK0/UxTuoMC6i2I/AAAAAAAAVGk/sd22_fZyU2E/s800/IMAG0226.jpg)
Not too bad
(https://lh4.googleusercontent.com/-CHiltgg9vGc/UxTupo2Bf7I/AAAAAAAAVGs/Mj12BfVnMmA/s800/IMAG0227.jpg)
Cyclone seal out
(https://lh6.googleusercontent.com/-Gy5Y_hRiKA0/UxTurA_B2EI/AAAAAAAAVG0/jtP_6AeeQ-k/s800/IMAG0228.jpg)
Fins off
(https://lh5.googleusercontent.com/-VN83fI_RVz4/UxTus-R5PfI/AAAAAAAAVG8/DbLx9JEFROg/s800/IMAG0229.jpg)
Shroud out
(https://lh4.googleusercontent.com/-pSJz1DuNhLM/UxTuub-GGbI/AAAAAAAAVHE/Wt8lFSVsumA/s800/IMAG0230.jpg)
I wish these stripped down more!
(https://lh6.googleusercontent.com/-IEaA6KVmAaU/UxTuwQUEorI/AAAAAAAAVHM/DoSfA8nznMs/s800/IMAG0231.jpg)
Dug the rod screw out
(https://lh4.googleusercontent.com/-6rQdFB-7sWs/UxTuyYVyzyI/AAAAAAAAVHU/Jw4jZyrTIck/s800/IMAG0232.jpg)
(https://lh6.googleusercontent.com/-OurbS8_I0og/UxTu0uoPhiI/AAAAAAAAVIw/KQbbqXGz7qc/s800/IMAG0233.jpg)
(https://lh3.googleusercontent.com/-9Dk0tR3Mac0/UxTu2roEYEI/AAAAAAAAVHk/fzaQBCsWXYI/s800/IMAG0234.jpg)
(https://lh4.googleusercontent.com/-ty2vEemYXqE/UxTu4RS6tPI/AAAAAAAAVHs/L7xlU_u0Aro/s800/IMAG0235.jpg)
Non washables (sad thing is I know where they ALL go without thinking!)
(https://lh5.googleusercontent.com/-oX36V7R3X4s/UxTu6xItfFI/AAAAAAAAVH0/W50zGRcMS9I/s800/IMAG0236.jpg)
(https://lh3.googleusercontent.com/-3n3qsQq6ACM/UxTu8yarQ6I/AAAAAAAAVH8/qArr0FkHuZs/s800/IMAG0237.jpg)
Will get it washed tomorrow once the drying DC07 Origin White is dry in the drying spot!
And to think this would have been taken to the tip due to that clog and brushroll! It did shit all when I tested it prior to stripping it down anyway!
Sorry for the delay! Bit retrospective but meh!
(https://lh4.googleusercontent.com/-E8AznGJLcq4/Uxgvvv7FG-I/AAAAAAAAVJg/ehyHOKmXKpc/s912/IMAG0244.jpg)
Changed the belts whilst everything was drying
(https://lh6.googleusercontent.com/-7fIhs0y1ER0/Uxgv0qYzQYI/AAAAAAAAVVE/m5DYNK8CxeM/s912/IMAG0245.jpg)
Flipped this round to avoid any clutch issues in the future
(https://lh6.googleusercontent.com/-LdiWLCHQerE/Uxgv5dDQZ-I/AAAAAAAAVJw/61EXBQcIBSE/s912/IMAG0246.jpg)
(https://lh5.googleusercontent.com/-F_JmYbU5OzA/Uxgv9trOS8I/AAAAAAAAVJ4/qrevZPR-S-A/s912/IMAG0247.jpg)
(https://lh3.googleusercontent.com/-DmT8Xo0idTg/UxgwBx8nWvI/AAAAAAAAVKA/CcZMFAM2bv8/s912/IMAG0248.jpg)
(https://lh5.googleusercontent.com/-gEhzb2Rtgws/UxgwF3KxmhI/AAAAAAAAVKI/VSSAVxGYRLY/s912/IMAG0249.jpg)
(https://lh3.googleusercontent.com/-NgZ6MoAOVOs/UxgwLgpIG0I/AAAAAAAAVVM/KDi_sX4ZbkE/s912/IMAG0250.jpg)
(https://lh5.googleusercontent.com/-P3mTBseYbY0/UxgwSGiA5iI/AAAAAAAAVKY/mmJGC6pJXp4/s912/IMAG0251.jpg)
(https://lh3.googleusercontent.com/-DebwkBneBNQ/UxgwgcqBiRI/AAAAAAAAVKo/1Xa_jEYXpzk/s912/IMAG0253.jpg)
Trivials done, time for re-assembly
(https://lh3.googleusercontent.com/-7p7LSB-Il2I/UxgwnB4WmqI/AAAAAAAAVKw/naZzDoHSZKw/s512/IMAG0261.jpg)
(https://lh6.googleusercontent.com/-ObsZ79L2hLE/UxgwrqPv4vI/AAAAAAAAVK4/FM1PXDx4-mc/s912/IMAG0262.jpg)
(https://lh6.googleusercontent.com/-tIcC1wqAUB0/UxgwvwPO7hI/AAAAAAAAVLA/GEeZ-84PYmg/s912/IMAG0263.jpg)
(https://lh3.googleusercontent.com/-hpIKveoA0DA/Uxgw0w3v4sI/AAAAAAAAVLI/6s2JHE5Tm-E/s912/IMAG0264.jpg)
(https://lh6.googleusercontent.com/-15emUBWqBnI/Uxgw5GKhDVI/AAAAAAAAVLQ/oT1inT6mdGU/s912/IMAG0265.jpg)
(https://lh3.googleusercontent.com/-EP2IrDnCcgs/UxgxCFsuuXI/AAAAAAAAVLg/2M9RBh5A-6s/s912/IMAG0267.jpg)
(https://lh5.googleusercontent.com/-5V3EqI5Ho88/UxgxG91t14I/AAAAAAAAVLo/1KLY1_IBvS4/s912/IMAG0268.jpg)
(https://lh5.googleusercontent.com/-wu-SnoHpsUA/UxgxLx4ZJtI/AAAAAAAAVLw/IHKYhHRQmG0/s912/IMAG0269.jpg)
(https://lh5.googleusercontent.com/-fbRNuadprXE/UxgxSmmWhgI/AAAAAAAAVL4/19GFyY7VlRY/s912/IMAG0270.jpg)
(https://lh3.googleusercontent.com/-2IftKQLxSFk/UxgxWxjPpbI/AAAAAAAAVVU/9ruHtoJ9eBs/s912/IMAG0271.jpg)
(https://lh6.googleusercontent.com/-obszeDShNac/UxgxbSnIR5I/AAAAAAAAVMI/09N5rMbJMXU/s912/IMAG0272.jpg)
(https://lh4.googleusercontent.com/-Q4zzTP8IHdw/UxgxfaiiXzI/AAAAAAAAVMQ/R6JL5C1N6vE/s912/IMAG0273.jpg)
(https://lh3.googleusercontent.com/-QSFWL_qH-ZY/Uxgxj_3P8NI/AAAAAAAAVMY/PPBsLlIJ2QQ/s912/IMAG0274.jpg)
(https://lh4.googleusercontent.com/-6roAUzZjOYI/UxgxpnNRoJI/AAAAAAAAVMg/xgoRXB13DgE/s912/IMAG0275.jpg)
(https://lh3.googleusercontent.com/-xxbed5kzHgY/UxgxxKoaktI/AAAAAAAAVMo/fWdNXD6cntE/s912/IMAG0276.jpg)
(https://lh6.googleusercontent.com/-sngI8Enk__M/Uxgx8a4UkUI/AAAAAAAAVMw/i8YQ4TDbP-M/s912/IMAG0277.jpg)
(https://lh6.googleusercontent.com/-E-t2rcKGzo8/Uxgx_spvVqI/AAAAAAAAVM4/bzLLdkTUg0g/s912/IMAG0278.jpg)
(https://lh4.googleusercontent.com/-Go3OVcNXY7w/UxgyEwKYLtI/AAAAAAAAVNA/2WekPP5bNcI/s912/IMAG0279.jpg)
(https://lh4.googleusercontent.com/-woArniHHXGI/UxgyJmO1QSI/AAAAAAAAVNI/uSxisM6c9ds/s912/IMAG0280.jpg)
(https://lh6.googleusercontent.com/-VvPzvGMtmWA/UxgyOcqkcKI/AAAAAAAAVNQ/-I80AjKAqbM/s912/IMAG0281.jpg)
(https://lh6.googleusercontent.com/-QutGKhN8f24/UxgyUU2sl_I/AAAAAAAAVNY/Lmu4xEE3sEw/s912/IMAG0282.jpg)
(https://lh3.googleusercontent.com/-vZSr2_7vrOE/UxgyYyYDBUI/AAAAAAAAVNg/zu0apH63G9M/s912/IMAG0283.jpg)
(https://lh6.googleusercontent.com/-UwLFdU5zHRY/UxgydTSAy4I/AAAAAAAAVNo/sFMOcVRXsnY/s912/IMAG0284.jpg)
(https://lh4.googleusercontent.com/-5CYu20E6CpY/UxgyxYf-7bI/AAAAAAAAVNw/nGgdZ-PZq7A/s912/IMAG0285.jpg)
(https://lh3.googleusercontent.com/-38vWPZi2L68/Uxgy4uR4CxI/AAAAAAAAVN4/y4AN2fbrczc/s912/IMAG0286.jpg)
(https://lh6.googleusercontent.com/-tBIR_PHARtU/UxgzfBVNwZI/AAAAAAAAVOA/c4BzyspiH8Q/s912/IMAG0287.jpg)
(https://lh4.googleusercontent.com/-PO5Vo190TGY/UxgziBWvw3I/AAAAAAAAVOI/dl8dB7jx8mw/s912/IMAG0288.jpg)
(https://lh3.googleusercontent.com/-X4NkCysY4ac/UxgzmkVQGII/AAAAAAAAVOQ/PCVuVxT0NYQ/s912/IMAG0289.jpg)
(https://lh6.googleusercontent.com/-wftVONTPj50/UxgzrE5VUjI/AAAAAAAAVOY/3DQQbR_DchQ/s912/IMAG0290.jpg)
(https://lh3.googleusercontent.com/-XEde102lqm8/UxgzvTotgZI/AAAAAAAAVOg/YUSDbstlveg/s912/IMAG0291.jpg)
(https://lh6.googleusercontent.com/-VCyoDsGKfbw/Uxgz0eHUcbI/AAAAAAAAVOo/Ya_CDH4lAM0/s912/IMAG0292.jpg)
(https://lh4.googleusercontent.com/-VzQgDz2IKtE/Uxgz4dl23rI/AAAAAAAAVOw/6QwFohAPPX0/s912/IMAG0293.jpg)
(https://lh3.googleusercontent.com/-sMi81ViI5HE/Uxgz8H2aL7I/AAAAAAAAVVc/EYHPbYq2arA/s912/IMAG0294.jpg)
(https://lh3.googleusercontent.com/-ZnYepr8ZOqY/Uxg0A_7bzoI/AAAAAAAAVPA/hTBepIeS0Ag/s912/IMAG0295.jpg)
(https://lh3.googleusercontent.com/-kUVp0ZfXze8/Uxg0E9ADgAI/AAAAAAAAVPI/SR8O065N_3w/s912/IMAG0296.jpg)
(https://lh5.googleusercontent.com/-DR9JeJFbze0/Uxg0JQn38CI/AAAAAAAAVPQ/TiXdPXrcVJg/s912/IMAG0297.jpg)
(https://lh4.googleusercontent.com/-piErwkqnXyc/Uxg0NhCNIuI/AAAAAAAAVPY/rfHCyZiAiG0/s912/IMAG0298.jpg)
(https://lh4.googleusercontent.com/-NiV1Rx3TwJo/Uxg0TNZL6kI/AAAAAAAAVPg/G3Bs-NHMLzE/s912/IMAG0299.jpg)
(https://lh3.googleusercontent.com/-540ySeBEoYA/Uxg0WZ4BggI/AAAAAAAAVdo/fcCSu4N22lU/s912/IMAG0300.jpg)
(https://lh4.googleusercontent.com/-Qsq_NEzCT40/Uxg0av5h0nI/AAAAAAAAVPw/ZYx1DADtay8/s912/IMAG0301.jpg)
(https://lh3.googleusercontent.com/-lDjzKx7zMGU/Uxg0fcktX9I/AAAAAAAAVP4/d8i-4f3R1_g/s912/IMAG0302.jpg)
(https://lh3.googleusercontent.com/-wtZgwTw3v7c/Uxg0oFq6PBI/AAAAAAAAVQA/Za7vEeTAOIE/s912/IMAG0303.jpg)
(https://lh6.googleusercontent.com/-O8e11WvE_FE/Uxg0tSuEYvI/AAAAAAAAVQI/Toqnm1VP9Hg/s912/IMAG0304.jpg)
(https://lh6.googleusercontent.com/-OcPQqXy7Rzo/Uxg2luZjjEI/AAAAAAAAVQU/No1aMGW_xlY/s912/IMAG0305.jpg)
(https://lh6.googleusercontent.com/-puXG8TgLXWg/Uxg2qSBs0tI/AAAAAAAAVQc/lHBkAnJ-7fY/s512/IMAG0306.jpg)
(https://lh3.googleusercontent.com/-PQEKWyleyFg/Uxg2twl7aOI/AAAAAAAAVQk/xciZjBJERBU/s912/IMAG0307.jpg)
(https://lh4.googleusercontent.com/-xzQOleVtyD0/Uxg22l_d1wI/AAAAAAAAVQs/ua_sJjpLyss/s912/IMAG0308.jpg)
(https://lh3.googleusercontent.com/-HQMk0-sFV0I/Uxg28ICqk1I/AAAAAAAAVQ0/HXU_efiYl0w/s912/IMAG0309.jpg)
(https://lh5.googleusercontent.com/-YgQGIGFlZWs/Uxg3ESofoRI/AAAAAAAAVQ8/Yn3ISyBBAJU/s912/IMAG0310.jpg)
(https://lh5.googleusercontent.com/-7Xhkn5dTEu0/Uxg3KVznJRI/AAAAAAAAVRE/7orZZbVC5jw/s912/IMAG0311.jpg)
(https://lh4.googleusercontent.com/-_nnaGjUwvx4/Uxg3RE3zYNI/AAAAAAAAVRM/dLO4GJHXWOU/s912/IMAG0312.jpg)
(https://lh5.googleusercontent.com/-Gl4wErvsS7k/Uxg3UnD68yI/AAAAAAAAVRU/2VP8z3BatnY/s912/IMAG0313.jpg)
(https://lh3.googleusercontent.com/-SYD7y-7ay4U/Uxg3axMjjTI/AAAAAAAAVRc/rbE2Wa5jB-E/s912/IMAG0314.jpg)
(https://lh3.googleusercontent.com/-A0h4CMcUhG0/Uxg3fWAtOdI/AAAAAAAAVRk/ql9dyj9y0ik/s912/IMAG0315.jpg)
(https://lh4.googleusercontent.com/-LBn2PL36ieU/Uxg3jzsUR-I/AAAAAAAAVRs/efFgeVEe3FE/s912/IMAG0316.jpg)
(https://lh5.googleusercontent.com/-MCbHSY5V_dY/Uxg3oT37omI/AAAAAAAAVR0/8sbQykJNvTA/s912/IMAG0317.jpg)
(https://lh5.googleusercontent.com/-u9nukTW5GHs/Uxg3srzecyI/AAAAAAAAVR8/WavFxbhvCAM/s912/IMAG0318.jpg)
(https://lh3.googleusercontent.com/-VRv6txoYw6A/Uxg3wW1ttuI/AAAAAAAAVSE/te6YTdCp51M/s912/IMAG0319.jpg)
(https://lh5.googleusercontent.com/-EMXLkoLUJR8/Uxg3zy75ZqI/AAAAAAAAVSM/1__sW1OtRv0/s912/IMAG0320.jpg)
(https://lh4.googleusercontent.com/-8sus8-HtsXI/Uxg33LM_rkI/AAAAAAAAVSU/hYvJx6EinOw/s912/IMAG0321.jpg)
(https://lh4.googleusercontent.com/-0BBBRrOs8RQ/Uxg36oqd3VI/AAAAAAAAVSc/PAhkaKFYBbg/s912/IMAG0322.jpg)
(https://lh4.googleusercontent.com/-5EFx-H83MxM/Uxg3-NBL0sI/AAAAAAAAVSk/nfnNsNSn5PY/s912/IMAG0323.jpg)
(https://lh4.googleusercontent.com/-QTnU17WqW8I/Uxg4BS-eULI/AAAAAAAAVSs/RhXVRUx5Xtw/s912/IMAG0324.jpg)
(https://lh5.googleusercontent.com/-PAqC3zwB-SU/Uxg4HfoToCI/AAAAAAAAVS0/TlgMtL-MxME/s912/IMAG0325.jpg)
(https://lh3.googleusercontent.com/-gO2TvLjrpxg/Uxg4LC7ir6I/AAAAAAAAVS8/suV1o5UbHeQ/s912/IMAG0326.jpg)
(https://lh5.googleusercontent.com/-fU74BB5-avM/Uxg4PWgTgcI/AAAAAAAAVTE/X0JQ693SmtA/s912/IMAG0327.jpg)
(https://lh3.googleusercontent.com/-wDS14Hfdpjs/Uxg4TQR97JI/AAAAAAAAVTM/07-G4CqqVwM/s512/IMAG0328.jpg)
(https://lh6.googleusercontent.com/-rI91J01Ll0o/Uxg4XxW6qsI/AAAAAAAAVTU/zgZeY1F3Vk8/s512/IMAG0329.jpg)
(https://lh3.googleusercontent.com/-ToMiTyb8hRQ/Uxg4by2LR2I/AAAAAAAAVTc/sM4XGCtsOq4/s912/IMAG0330.jpg)
(https://lh6.googleusercontent.com/-Dw_rQyE4PzU/Uxg4f_ZyxBI/AAAAAAAAVTk/TBmRymWG_ZE/s912/IMAG0331.jpg)
(https://lh3.googleusercontent.com/-XCyt0hN6e0w/Uxg4nFlSu_I/AAAAAAAAVT0/baqswkXRIbI/s912/IMAG0333.jpg)
(https://lh3.googleusercontent.com/-I8sWhfFP7_I/Uxg4qmYYs5I/AAAAAAAAVT8/rtsXb1jC2c0/s912/IMAG0334.jpg)
(https://lh5.googleusercontent.com/-evnNRh2vGbw/Uxg4uCOQWcI/AAAAAAAAVUE/A_mPy3G8VoI/s912/IMAG0335.jpg)
(https://lh5.googleusercontent.com/-Sen5LzY8OCU/Uxg4xt66toI/AAAAAAAAVUM/QU-gZ8mmOWk/s912/IMAG0336.jpg)
(https://lh6.googleusercontent.com/-bFCz0swEjAw/Uxg425reYxI/AAAAAAAAVVk/S0Cz_we4VBE/s912/IMAG0337.jpg)
(https://lh3.googleusercontent.com/-AMfs7qWLS00/Uxg47Loqs5I/AAAAAAAAVUc/kyXNx6UJ3Ws/s512/IMAG0338.jpg)
(https://lh3.googleusercontent.com/-FTvPy9WmS34/Uxg4-25HqHI/AAAAAAAAVUk/2UGR0PHv5uY/s912/IMAG0339.jpg)
And good as new! Up for sale now, below are the poncy pictures of it!
(https://lh3.googleusercontent.com/-j1Qjp8yaxq4/UxuXw5M8mpI/AAAAAAAAVao/QbbiPvU0TL4/s512/IMAG0373.jpg)
(https://lh3.googleusercontent.com/-vqF_wD3J3m0/UxuXzSnq_DI/AAAAAAAAVaw/K3tZZpHwSp0/s512/IMAG0374.jpg)
(https://lh5.googleusercontent.com/-RyaWU8VH6bU/UxuX1ExhIQI/AAAAAAAAVa4/AQ_JOlzxy7g/s912/IMAG0375.jpg)
