Dyson Models => First Generation "The Ball" Dysons. => Topic started by: beko1987 on March 15, 2015, 11:45:52 am
I bought a DC24 and 25 last week, and did the 24 first
(https://lh4.googleusercontent.com/-9ItV386_jp0/VPN4xgauqAI/AAAAAAAAjJI/1-WEolKQ2ic/s512/upload_-1.jpg)
Was a bit filthy
(https://lh4.googleusercontent.com/-Q-dOBiWArAg/VPN4z2x9_ZI/AAAAAAAAjJQ/WVlsl0Dg3NI/s512/upload_-1.jpg)
(https://lh3.googleusercontent.com/-x7wC7nzM9h0/VPN412pQQeI/AAAAAAAAkM0/IMz8wIPAtCI/s800/upload_-1.jpg)
Pre filter wasnt too horiffic, very very dusty though
(https://lh6.googleusercontent.com/-Hs8PhjPESkA/VPN43z_zbHI/AAAAAAAAkM8/gsskMRIlcRU/s800/upload_-1.jpg)
(https://lh6.googleusercontent.com/-1ygb3HdDfhM/VPN453138lI/AAAAAAAAjJo/wRXQsbHiHNs/s800/upload_-1.jpg)
(https://lh6.googleusercontent.com/-gLBDIREPRxA/VPN471xPeYI/AAAAAAAAjJw/3BnnznYis1k/s800/upload_-1.jpg)
Post filter was :dead-dyson: though
(https://lh5.googleusercontent.com/-oCuwtkv4Qwg/VPN49oRzYjI/AAAAAAAAjJ4/Ks4J5fZhyIc/s800/upload_-1.jpg)
(https://lh4.googleusercontent.com/-6bTJpPjxbrc/VPN4_LHQHII/AAAAAAAAkNE/w6Kzq62Iehg/s800/upload_-1.jpg)
(https://lh4.googleusercontent.com/-hGxcU8NNy3Y/VPN5BKSwhvI/AAAAAAAAjKI/pePtGAf1304/s512/upload_-1.jpg)
Eva loved the toy dyson...
(https://lh5.googleusercontent.com/-WmvIo5REHqc/VPN5C48a2aI/AAAAAAAAjKQ/0f-tf5G1j04/s512/upload_-1.jpg)
we took the cyclone off
(https://lh5.googleusercontent.com/-mG65WrwQCoM/VPN5EvMba-I/AAAAAAAAjKY/gQ7iPO8SCiQ/s512/upload_-1.jpg)
I left the wand whole to wash
(https://lh4.googleusercontent.com/-xWAH4C83j7A/VPN5G1FBSvI/AAAAAAAAjKg/NjqqS7IeLSI/s800/upload_-1.jpg)
The sticker was long gone, so I scraped it off
(https://lh3.googleusercontent.com/-HUk2BiXf1lE/VPN5Ib7qHVI/AAAAAAAAjKo/iUKAks5KfkQ/s800/upload_-1.jpg)
and took the top cap off
(https://lh3.googleusercontent.com/-kMuvOk1uECM/VPN5NomFFtI/AAAAAAAAjLA/Mvzm0PftyMc/s800/upload_-1.jpg)
(https://lh5.googleusercontent.com/--lH8zkaYJuQ/VPN5P6vGF9I/AAAAAAAAjLI/-9dCIV0Sees/s800/upload_-1.jpg)
(https://lh6.googleusercontent.com/-xTphGo4VhcM/VPN5Rhfsf3I/AAAAAAAAjLQ/a177ywNxYSw/s800/upload_-1.jpg)
hose off
(https://lh4.googleusercontent.com/-REepNEKYKqc/VPN5TkKO_VI/AAAAAAAAjLY/rAJic6QMuMc/s800/upload_-1.jpg)
(https://lh6.googleusercontent.com/-ydmNXcAC150/VPN5VUhliQI/AAAAAAAAjLg/7Ev0iaME2sI/s800/upload_-1.jpg)
combi tool wasnt horrific
(https://lh6.googleusercontent.com/-xDG0r4CzCCk/VPN5XQKVV2I/AAAAAAAAjLo/1bDkoe6zSiE/s800/upload_-1.jpg)
(https://lh4.googleusercontent.com/-mY53tuBWnYM/VPN5Y1bll4I/AAAAAAAAjLw/x4xoG5OaIDY/s800/upload_-1.jpg)
Switch housing off next
(https://lh4.googleusercontent.com/-JENwBzCrJH4/VPN5aqf2J2I/AAAAAAAAjL4/_QMHgFaEoNI/s512/upload_-1.jpg)
(https://lh6.googleusercontent.com/-Hq2z7rvcdNc/VPN5cLHOUrI/AAAAAAAAjMA/7gBs0hV-U8U/s800/upload_-1.jpg)
little spring here
(https://lh3.googleusercontent.com/--bBJGp1EwJc/VPN5d3I8M8I/AAAAAAAAjMI/akazkkh0SHY/s800/upload_-1.jpg)
(https://lh5.googleusercontent.com/-fPAtvYkkuhg/VPN5fj2bqNI/AAAAAAAAjMQ/hW4RtkywWn4/s800/upload_-1.jpg)
I left this clear bit on as it looks like itll break if I try
(https://lh5.googleusercontent.com/-xz0GNztNnVQ/VPN5hVXY3EI/AAAAAAAAjMY/Td16YR-akv4/s800/upload_-1.jpg)
Switches out
(https://lh6.googleusercontent.com/-o_5Nwew9W1c/VPN5jPoGPEI/AAAAAAAAjMg/sbX4i4iKbPE/s800/upload_-1.jpg)
(https://lh5.googleusercontent.com/-i2z0p2UE3R8/VPN5kseD32I/AAAAAAAAjMo/JN_df0qaAIA/s800/upload_-1.jpg)
(https://lh3.googleusercontent.com/-hwxUc-2UMFo/VPN5maLuY9I/AAAAAAAAjMw/Llif1qul7No/s800/upload_-1.jpg)
(https://lh5.googleusercontent.com/-FhOt8lQjaPI/VPN5n6pifaI/AAAAAAAAjM4/F8DEgLSAZtg/s800/upload_-1.jpg)
and pull the cable off the front of the cleaner
(https://lh5.googleusercontent.com/-B9XvVMwrMvc/VPN8MgHL7NI/AAAAAAAAjNE/MrSSbs1SqbY/s512/upload_-1.jpg)
remove the [attach=1]
(https://lh3.googleusercontent.com/-kRJF22mIbag/VPN8OlNZQRI/AAAAAAAAjNM/q36LDfQOUP4/s800/upload_-1.jpg)
and the other [attach=1]
(https://lh6.googleusercontent.com/-kcL9Rx-8yaI/VPN8SfQ5heI/AAAAAAAAjNc/IXQj872cyuY/s800/upload_-1.jpg)
Brushroll housing off
(https://lh6.googleusercontent.com/-3NMsmpTBWEU/VPN8UPeu0MI/AAAAAAAAjNk/9xfV0akoIF4/s800/upload_-1.jpg)
lower hose off
(https://lh5.googleusercontent.com/-90PXj3NO-gE/VPN8V6He0vI/AAAAAAAAjNs/qnQd3UZ2EWE/s800/upload_-1.jpg)
LH Ball screw out
(https://lh5.googleusercontent.com/-dd_jGpSvn6Y/VPN8Zca0XwI/AAAAAAAAjN8/oq4KwLkaUmE/s800/upload_-1.jpg)
RH Wiring cover screws removed
(https://lh4.googleusercontent.com/-4BPmV_lWMgw/VPN8a8LJY5I/AAAAAAAAjOE/OXkHQr9aTXg/s800/upload_-1.jpg)
(https://lh4.googleusercontent.com/-QhcnfJMITnc/VPN8csseXII/AAAAAAAAjOM/yIMjTSTuAlc/s800/upload_-1.jpg)
Pop the white connector up
(https://lh4.googleusercontent.com/-pb4CrwFJbhQ/VPN8erfe0NI/AAAAAAAAjOU/TNZzHphFkjQ/s800/upload_-1.jpg)
and unplug it
(https://lh4.googleusercontent.com/-EnWJuwRT-AU/VPN8gcMvHmI/AAAAAAAAjOc/-hgNdWYC46Y/s800/upload_-1.jpg)
remove the microswitch housing screw
(https://lh5.googleusercontent.com/-A0l-dM8D5fo/VPN8iLmJxpI/AAAAAAAAjOk/OlfAFiBlGm4/s800/upload_-1.jpg)
(https://lh5.googleusercontent.com/-mhhNvJz7eGs/VPN8j2nyHTI/AAAAAAAAjOs/ek-rhdpUi9s/s800/upload_-1.jpg)
remove the little spring
(https://lh4.googleusercontent.com/-7Kz10QAAkdY/VPN8lmqeqiI/AAAAAAAAjO0/6hBSwvQb_VQ/s800/upload_-1.jpg)
the housing pulls out from behind the pivot for the grey pedal
(https://lh4.googleusercontent.com/-VjD7xq8mVDU/VPN8nfzPnuI/AAAAAAAAjO8/2r0SIaGt4-k/s800/upload_-1.jpg)
unplug the wires and remove the switch from the housing
(https://lh3.googleusercontent.com/-umUN6kvlIhA/VPN8pASjqWI/AAAAAAAAjPE/X3oVdWENSX8/s800/upload_-1.jpg)
(https://lh5.googleusercontent.com/-aWDeqYtTJa8/VPN8q34m_SI/AAAAAAAAjPM/9nuwNDANbTQ/s800/upload_-1.jpg)
remove the RH ball screw
(https://lh5.googleusercontent.com/-8TRRQAwaZhE/VPN8snWL1hI/AAAAAAAAjPU/_qSHW4E_yIA/s800/upload_-1.jpg)
The ball then pulls off the chassis
(https://lh3.googleusercontent.com/-scjRDdn6TsU/VPN8uhZJEoI/AAAAAAAAjPc/w-m56lJr44c/s800/upload_-1.jpg)
(https://lh5.googleusercontent.com/-zx2FDcnslEs/VPN8w1GiVpI/AAAAAAAAjPk/bLvS06po2Mw/s800/upload_-1.jpg)
Pull the chassis wires off and remove the chassis spine wire
(https://lh5.googleusercontent.com/-d1ofvn_qrV0/VPN8ysOfFsI/AAAAAAAAjPs/nxRf7H0Fk6c/s800/upload_-1.jpg)
Remove the RH Red pedal screw
(https://lh5.googleusercontent.com/-MKKsw-PXXHo/VPN80XDYyeI/AAAAAAAAjP0/yp2XS_8hYAE/s800/upload_-1.jpg)
and the left
(https://lh5.googleusercontent.com/-JX6bqdLFcLQ/VPN82An1cLI/AAAAAAAAjP8/d_s0tBlh7fE/s800/upload_-1.jpg)
remove the LH grey pedal screw
(https://lh3.googleusercontent.com/-YI2acXvsYuk/VPN83qmRjEI/AAAAAAAAjQE/nqfjRfdD3mM/s800/upload_-1.jpg)
The grey and red pedals unclip from the chassis now
(https://lh5.googleusercontent.com/-LosObsym8Ws/VPN85YJ8T7I/AAAAAAAAjQM/T3xwWKUZdBY/s800/upload_-1.jpg)
The LH has 2 springs on it
(https://lh4.googleusercontent.com/-Z48JKvz4vGU/VPN87InsQeI/AAAAAAAAjQU/BDSmxNfOCp8/s800/upload_-1.jpg)
and once their removed the red and grey pedals can be removed and seperated
(https://lh3.googleusercontent.com/-Kzm-IMEkzdE/VPN89J7z16I/AAAAAAAAjQc/ghFXIHsR4PU/s800/upload_-1.jpg)
The black clip by the ball unscrews now
(https://lh6.googleusercontent.com/-Vh_x2pGxCrs/VPN9BDGmMKI/AAAAAAAAjQs/3LOttpOnl40/s800/upload_-1.jpg)
(https://lh6.googleusercontent.com/-4zB0VL7INE4/VPN9Cz83KFI/AAAAAAAAjQ0/k6eV2hSylTY/s800/upload_-1.jpg)
The spring pops off the end
(https://lh5.googleusercontent.com/-1_s26KGk6io/VPN9EocPgII/AAAAAAAAjQ8/iTdcKCys5EA/s800/upload_-1.jpg)
Changeover valve to remove now
(https://lh6.googleusercontent.com/-p001D5I80pU/VPN9GjYEVlI/AAAAAAAAjRE/0XfC4Nj-hBw/s800/upload_-1.jpg)
time for a smaller torx driver
(https://lh4.googleusercontent.com/-AGLICymsdmc/VPN9IfsLhMI/AAAAAAAAjRM/7Ohkb5L1mog/s512/upload_-1.jpg)
to remove the changeover wheel screw
(https://lh4.googleusercontent.com/-j_H5JxD6H5A/VPN9J2UBjKI/AAAAAAAAjRU/XH2vmetsDPo/s800/upload_-1.jpg)
slide the wheel off the arm
(https://lh4.googleusercontent.com/-7bG-MM2dsrw/VPN9Lre20rI/AAAAAAAAjRc/ckJnljCMD8w/s800/upload_-1.jpg)
undo the screws underneath holding the changeover assembly on
(https://lh5.googleusercontent.com/-Z7TRH03h-2s/VPN9NiSrtPI/AAAAAAAAjRk/CGRRwvsbMdA/s800/upload_-1.jpg)
(https://lh5.googleusercontent.com/-CgV2H9c5Vy8/VPN9PW-I3TI/AAAAAAAAjRs/Li6luEz-ofs/s800/upload_-1.jpg)
which splits into two again
(https://lh4.googleusercontent.com/-Ej562fF-i8A/VPN9RSqrNbI/AAAAAAAAjR0/8PWqbXg71GY/s800/upload_-1.jpg)
with another spring on
(https://lh5.googleusercontent.com/-VlRE65BdrkA/VPN9TPyNPiI/AAAAAAAAjR8/KiMxxDlZKV8/s800/upload_-1.jpg)
this spring gives the yolk assembly some bounce
(https://lh6.googleusercontent.com/-rYcip038C2Q/VPN9VNIOSPI/AAAAAAAAjSE/jVTVArSOWoc/s800/upload_-1.jpg)
Next is the diverter flap
(https://lh5.googleusercontent.com/-LLpqDg4hRR4/VPN9YozTYTI/AAAAAAAAjSU/SeBzjxXS3mw/s800/upload_-1.jpg)
remove the screw, push the centre through and the spring comes out
(https://lh6.googleusercontent.com/-NRVHUIuxTCw/VPN9ahTkpnI/AAAAAAAAjSc/RaOMEOEsb9k/s800/upload_-1.jpg)
then the flap unclips
(https://lh3.googleusercontent.com/-C-hfg7B5t2c/VPN9cUzavTI/AAAAAAAAjSk/kD3jw02lgcA/s800/upload_-1.jpg)
another [attach=1] comes off
(https://lh5.googleusercontent.com/-XdPEyLXWiSw/VPN9eB_RZcI/AAAAAAAAkNM/KF2IUnWBD2A/s800/upload_-1.jpg)
Second hose now
(https://lh6.googleusercontent.com/-RLuSL8w8r3o/VPN9gDfe6FI/AAAAAAAAjS0/cdwF1pjVhZg/s800/upload_-1.jpg)
and the changeover top
(https://lh6.googleusercontent.com/-S37SPIKe2Ps/VPN9iBYGiAI/AAAAAAAAjS8/UEKrt7ld7u8/s800/upload_-1.jpg)
Stripped chassis
(https://lh3.googleusercontent.com/-mukLi-ggtro/VPN9kGKvO8I/AAAAAAAAjTE/uPpvASCWXsI/s512/upload_-1.jpg)
Onto the motor now
(https://lh4.googleusercontent.com/-qBx39k_gpAY/VPN9lzahj7I/AAAAAAAAjTM/Nj7i7p6YwNk/s800/upload_-1.jpg)
Wiring has to be removed
(https://lh4.googleusercontent.com/-nJpaYVuX11c/VPN9no3OLhI/AAAAAAAAjTU/lAc64Igpy9w/s800/upload_-1.jpg)
More wires run inderneath
(https://lh6.googleusercontent.com/-8Cw6YCd-DHY/VPN9pl1E2kI/AAAAAAAAjTc/sOs4Fslm_v4/s800/upload_-1.jpg)
(https://lh6.googleusercontent.com/-JXwHlW9JxGs/VPN9rcy9iOI/AAAAAAAAjTk/72UV-muV3S0/s800/upload_-1.jpg)
(https://lh3.googleusercontent.com/-Zahpazf6jzw/VPN9tHavqEI/AAAAAAAAjTs/K64BZNiAFbU/s800/upload_-1.jpg)
There's a screw under the yolk assembly
(https://lh4.googleusercontent.com/-KmuM1jTVl9o/VPN9u3zlNBI/AAAAAAAAjT0/HOBqR1mTSPw/s800/upload_-1.jpg)
and the wiring cover pops off
(https://lh4.googleusercontent.com/-2kJtQs8iS-M/VPN9wSS_unI/AAAAAAAAjT8/McMUm35c9Kg/s800/upload_-1.jpg)
The brushroll housing connector removes now
(https://lh3.googleusercontent.com/-dDEtyYuONOU/VPN9yKlvzqI/AAAAAAAAjUE/d-qXd64Jl1Q/s800/upload_-1.jpg)
Open the flap on top of the connector
(https://lh6.googleusercontent.com/-J_sEF0X9OSc/VPN9zni82cI/AAAAAAAAjUM/iHkU-JlSA9Y/s800/upload_-1.jpg)
and the wires pull out of the connector
(https://lh5.googleusercontent.com/-gQK2K-n7Erc/VPN91ZQYk6I/AAAAAAAAjUU/nfVSxwhNZeE/s800/upload_-1.jpg)
The floating locating bracket on top removes
(https://lh6.googleusercontent.com/-sw0xxO3uqys/VPN93D3SovI/AAAAAAAAjUc/c7eYpVMu7yY/s800/upload_-1.jpg)
it has a little spring underneath
(https://lh4.googleusercontent.com/-1lYfQwlAcXc/VPN9401FDsI/AAAAAAAAjUk/CSNlqcCRgwQ/s800/upload_-1.jpg)
The end of it unscrews to reveal an elbow
(https://lh5.googleusercontent.com/-ERL2Yju7oIo/VPN96XfMPoI/AAAAAAAAjUs/H1ucBVcp_BE/s800/upload_-1.jpg)
The yolk is stripped
(https://lh3.googleusercontent.com/-_LlynYDOEUo/VPN993J8MEI/AAAAAAAAjU8/FHEDV0MbIDg/s800/upload_-1.jpg)
Onto the ball
(https://lh6.googleusercontent.com/-S6sUWJpr-Sw/VPN9_6q3rPI/AAAAAAAAjVE/cX7iNfQK3i8/s800/upload_-1.jpg)
Remove the post filter cover
(https://lh3.googleusercontent.com/-LezQWkdwS7Q/VPN-Bns5I4I/AAAAAAAAjVM/ct5ncVq_8aQ/s800/upload_-1.jpg)
(https://lh4.googleusercontent.com/-4iWqJ-IrSz8/VPN-DPnAhqI/AAAAAAAAjVU/H7OKWv-XgtU/s800/upload_-1.jpg)
(https://lh3.googleusercontent.com/-as4XOmCyeuQ/VPN-FHJzqXI/AAAAAAAAjVc/HGWeoczZsrk/s800/upload_-1.jpg)
remove the 4 screws and the ball seperates
(https://lh5.googleusercontent.com/-cEx5WhtmnH4/VPN-HOvh_RI/AAAAAAAAjVk/syTIo6KLbas/s800/upload_-1.jpg)
(https://lh4.googleusercontent.com/-JwDR1Yf_5DY/VPN-I1bNpaI/AAAAAAAAjVs/3RXiPyhXXUk/s800/upload_-1.jpg)
The two cogs remove
(https://lh5.googleusercontent.com/-UvtImivGhSM/VPN-KXYQOoI/AAAAAAAAjV0/H125l2ogyUk/s800/upload_-1.jpg)
Remove the 4 screws on the motor housing and remove the top ocver, but beware the cables
(https://lh6.googleusercontent.com/-ucFLFlihMd4/VPN-MCpKvYI/AAAAAAAAjV8/f4v4IGhThzk/s800/upload_-1.jpg)
push the connector and cables through
(https://lh5.googleusercontent.com/-oBH6ER7Ay5c/VPN-Ocz88nI/AAAAAAAAjWE/b-4oI0p4-t8/s800/upload_-1.jpg)
(https://lh4.googleusercontent.com/-66F4p0gATLA/VPN-QDEgkdI/AAAAAAAAjWM/OZ-O2swaSDg/s800/upload_-1.jpg)
Motor was a bit dusty
(https://lh5.googleusercontent.com/-oS4Vrh1r6SU/VPN-SJr1yEI/AAAAAAAAjWU/n0VXTMCwaQA/s800/upload_-1.jpg)
(https://lh3.googleusercontent.com/-sSUlhqJosNk/VPN-TrIdJ0I/AAAAAAAAjWc/yD1sZos14b0/s800/upload_-1.jpg)
the 2 motor wires unclip
(https://lh6.googleusercontent.com/-zgVAlzC9hSE/VPN-WzzLizI/AAAAAAAAkNU/d1kH5dritbk/s800/upload_-1.jpg)
and the motor rubber can be removed
(https://lh6.googleusercontent.com/-hwFJD4_1r14/VPN-Y5TbtQI/AAAAAAAAjW0/MAY7SPvAVeE/s800/upload_-1.jpg)
(https://lh6.googleusercontent.com/-rCrV4sYCZR8/VPN-aq-grGI/AAAAAAAAjW8/IN07w2LhzfM/s800/upload_-1.jpg)
top motor mount off
(https://lh3.googleusercontent.com/-KldutM5tbjE/VPN-cHLXDpI/AAAAAAAAjXE/2Uk5uFFGcSc/s800/upload_-1.jpg)
Brushroll housing now
(https://lh6.googleusercontent.com/-no3w5BGgOh0/VPN-eLKiIFI/AAAAAAAAjXM/S4eFXlOBF0c/s800/upload_-1.jpg)
(https://lh6.googleusercontent.com/-OeErFz_di9Y/VPN-gB_2ngI/AAAAAAAAjXU/8Jb3H4g7Xa8/s800/upload_-1.jpg)
remove the brushroll
(https://lh3.googleusercontent.com/-mld-vRtKe8g/VPN-hwb4AfI/AAAAAAAAjXc/otz2S23ne-U/s800/upload_-1.jpg)
squeegee is removed from the baseplate
(https://lh3.googleusercontent.com/-YpHxZBwV9A8/VPN-lfBGLWI/AAAAAAAAjXs/0D-LjVtZPk8/s800/upload_-1.jpg)
Which you need to do to undo all the screws. Once their all out, flip it over and lift the top grey housing off
(https://lh6.googleusercontent.com/-E0OSBIFeZpI/VPN-nVYtscI/AAAAAAAAjX0/ok_O0nbdelU/s800/upload_-1.jpg)
Pull the front bumper off
(https://lh3.googleusercontent.com/-taE8SHHXchA/VPN-pRCyjgI/AAAAAAAAjX8/lXVJYZ8nssU/s800/upload_-1.jpg)
The clear plastic part lifts away, and the motor and pcb can be removed
(https://lh5.googleusercontent.com/-d5E_S_FEVsM/VPN-roibETI/AAAAAAAAjYE/ugrChUjCLEU/s800/upload_-1.jpg)
Remove the wheels from the soleplate
(https://lh3.googleusercontent.com/-pCEtCwnnZH8/VPN-tR-GsLI/AAAAAAAAkNc/IXjyp7WUXsU/s800/upload_-1.jpg)
The PCB and motor
(https://lh6.googleusercontent.com/-fvphTvsudgA/VPN-vQzR6WI/AAAAAAAAjYU/12dQ73NLl3Y/s800/upload_-1.jpg)
This connector needs to be removed
(https://lh5.googleusercontent.com/-B5AB35x2fR0/VPN-xObpsXI/AAAAAAAAjYc/u35_dOsLoAg/s800/upload_-1.jpg)
the end pops off the the wires and inner housing pop out of the slot
(https://lh5.googleusercontent.com/-dIJqJ1_ofyM/VPN-y6piAdI/AAAAAAAAjYk/Vn7lsO2ECh4/s800/upload_-1.jpg)
(https://lh5.googleusercontent.com/-AOIybEudvmE/VPN-0vbfp0I/AAAAAAAAjYs/O3wXDboXJDk/s800/upload_-1.jpg)
Onto the cyclone
(https://lh5.googleusercontent.com/-KBPTWjdIq8M/VPN-2ZpgRZI/AAAAAAAAjY0/KU8uXSR7h1o/s512/upload_-1.jpg)
bottom flap and bottom seal pop off
(https://lh6.googleusercontent.com/-1JWOjCvvKak/VPN-4WQFO6I/AAAAAAAAjY8/6OJD315Q1vk/s800/upload_-1.jpg)
top filter catch pops off the hinges
(https://lh5.googleusercontent.com/-EoSPNpYlrzk/VPN-6eJMHDI/AAAAAAAAjZE/HuIP8vt7RT8/s800/upload_-1.jpg)
3 manky screws to remove the top handle
(https://lh5.googleusercontent.com/-jrNKIrb79hE/VPN-8PQp9LI/AAAAAAAAjZM/R3aqI5cCaXw/s800/upload_-1.jpg)
(https://lh4.googleusercontent.com/-of2p8Zj7qHs/VPN-_jYSWFI/AAAAAAAAjZc/zV2Fkfyalw8/s800/upload_-1.jpg)
more screws to remove from the inner cyclone
(https://lh6.googleusercontent.com/-oEueQmiu1xE/VPN_BAkaoAI/AAAAAAAAjZk/4XGCItSKpjs/s800/upload_-1.jpg)
part of the bin release rod and spring comes out when this is seperated
(https://lh5.googleusercontent.com/-VuLwOSJ-drY/VPN_C0UmdKI/AAAAAAAAjZs/-InwqgKUc2A/s800/upload_-1.jpg)
rather ruined cyclone seal
(https://lh6.googleusercontent.com/-QW9WgpRxxK8/VPN_EzhTE1I/AAAAAAAAjZ0/JI3fVASMEBk/s800/upload_-1.jpg)
(https://lh3.googleusercontent.com/-z3yBxvddyWo/VPN_G7A4Q0I/AAAAAAAAjZ8/ycasVJUqJ4Y/s800/upload_-1.jpg)
Theres a seal around the middle part of the cyclone
(https://lh5.googleusercontent.com/-V83PnbTXrY4/VPN_Iss3M8I/AAAAAAAAjaE/C4x5ns9QYfU/s800/upload_-1.jpg)
The shroud pops off the cones
(https://lh6.googleusercontent.com/-dLxLSTbgZyQ/VPN_KoM4p7I/AAAAAAAAjaM/O12UnnkpG2Y/s800/upload_-1.jpg)
and the lower cone pops off the shroud
(https://lh5.googleusercontent.com/-aWNWzq_MOaw/VPN_Mu__kAI/AAAAAAAAjaU/QdX-JQKIUv0/s800/upload_-1.jpg)
And she was disassembled. And washed dried and polished...
Starting with the cyclone
(https://lh5.googleusercontent.com/-Ep8-28A49-g/VP9VKlsvZYI/AAAAAAAAkAs/U9tTIWjeaFA/s800/upload_-1.jpg)
bottom cone [attach=1] on
(https://lh3.googleusercontent.com/-LybRHvck4us/VP9VMS6OjsI/AAAAAAAAkA0/t4uPD1L1Jf8/s800/upload_-1.jpg)
(https://lh3.googleusercontent.com/-KnPa4lgVf3I/VP9VODw7qLI/AAAAAAAAkA8/vZYEZ66eiyI/s800/upload_-1.jpg)
Cone back onto the shroud
(https://lh3.googleusercontent.com/-3atIPqWn1RY/VP9VP35UvfI/AAAAAAAAkBE/CpC2XRi7N3A/s800/upload_-1.jpg)
shroud back onto the cone assembly
(https://lh5.googleusercontent.com/-yuyCt6v9XK0/VP9VRoVb6aI/AAAAAAAAkBM/M8FvvVo-nKM/s800/upload_-1.jpg)
Top now
(https://lh5.googleusercontent.com/-Z7PudBcNvA0/VP9VTXosA1I/AAAAAAAAkBU/p8a0vV8fRxw/s800/upload_-1.jpg)
handle and the top of the release rod back on
(https://lh5.googleusercontent.com/-vpTr2v4iTC8/VP9VVFoZKgI/AAAAAAAAkBc/lSfWtXcCYwA/s800/upload_-1.jpg)
[attach=1] back onto the cyclone bottom flap
(https://lh4.googleusercontent.com/-jCowDAvfI6k/VP9VW0Z5gLI/AAAAAAAAkBk/-jUjdXzLrd4/s800/upload_-1.jpg)
Bin is very cloudy but came up ok after a polish. Got rid of the very battered sticker though to smarten it up a bit
(https://lh3.googleusercontent.com/-66w4VAxDNUY/VP9VYkZVh6I/AAAAAAAAkBs/e24S7MKDZKE/s512/upload_-1.jpg)
The motor was cleaned up
(https://lh6.googleusercontent.com/-43UUGv9mtms/VP9VaLg-NsI/AAAAAAAAkB0/STwMcOmktIg/s800/upload_-1.jpg)
2 seals back on
(https://lh3.googleusercontent.com/-UyUPxsf_m28/VP9Vb6kkUII/AAAAAAAAkB8/_wsEZCTvQqw/s800/upload_-1.jpg)
The motor connectors were plugged in and nestled into the gap in the seal assembly and the motor was inserted into the motor housing
(https://lh6.googleusercontent.com/-K7PoT5_th7M/VP9Vd77XhOI/AAAAAAAAkCE/CdTkKKA58rA/s800/upload_-1.jpg)
Feed the wires through the hole and push the rubber seal into it
(https://lh5.googleusercontent.com/-TsZqlAhiYgE/VP9VfSoQDYI/AAAAAAAAkCM/nnaXItIiWyM/s800/upload_-1.jpg)
Feed the wires through the cable routing bit on top of the housing
(https://lh4.googleusercontent.com/-k9PTWUTL9Vg/VP9Vg-IJ7xI/AAAAAAAAkCU/8xR5HFoKQIw/s800/upload_-1.jpg)
Split the large ball bearing
(https://lh4.googleusercontent.com/-4105qWLDukQ/VP9ViyLh19I/AAAAAAAAkCc/gmp60y9w15w/s800/upload_-1.jpg)
put a good smear of grease around it
(https://lh5.googleusercontent.com/--nRJO1sYLZY/VP9VkdhcoWI/AAAAAAAAkCk/OsvJypD2jMQ/s800/upload_-1.jpg)
and snap the housing back together
(https://lh4.googleusercontent.com/-T3A2Di8NMpg/VP9Vl73N7KI/AAAAAAAAkCs/o2Tf-SFCpXw/s800/upload_-1.jpg)
fit it to the ball
(https://lh3.googleusercontent.com/-zrTMPjcoL4s/VP9Vn6TQQXI/AAAAAAAAkC0/LT2sU2lnmz0/s800/upload_-1.jpg)
fit the other white bearing to the other end and sit the housing into one side of the ball
(https://lh6.googleusercontent.com/-c5lEP4AHI18/VP9VphysDuI/AAAAAAAAkC8/EUwYNLwtvk4/s800/upload_-1.jpg)
lower the other half of the ball on
(https://lh4.googleusercontent.com/-lpRcl0Y41LU/VP9VrelvQOI/AAAAAAAAkDE/EZw2yaJxLNE/s800/upload_-1.jpg)
and screw together.
Onto the yolk now, refit the elbow to the end of the yolk assembly
(https://lh5.googleusercontent.com/-R32TEdoPrYA/VP9VtYuckKI/AAAAAAAAkDM/A9afGklqAbU/s800/upload_-1.jpg)
(https://lh4.googleusercontent.com/-c1gQQRoP1BU/VP9Vu1MlElI/AAAAAAAAkDU/5LFNA1qSoGE/s800/upload_-1.jpg)
snap the bouncy bar onto the top
(https://lh5.googleusercontent.com/-PbcQz2HGJHo/VP9VwptDpuI/AAAAAAAAkDc/aLodo3iCJBE/s800/upload_-1.jpg)
feed the yolk wires through the gap in the housing, then plug the ends back into the plug in this orientation.
(https://lh6.googleusercontent.com/-2n5DDSa52aM/VP9VyTxte0I/AAAAAAAAkDk/HiT3ICCQ9Wg/s800/upload_-1.jpg)
close the plug
(https://lh6.googleusercontent.com/-qbJhxEUJRQM/VP9Vz627YtI/AAAAAAAAkDs/bwD3onzu8pI/s800/upload_-1.jpg)
refit the plug into the housing, then push the wires into their holders
(https://lh3.googleusercontent.com/-qw4yj3QiDPQ/VP9V11uYShI/AAAAAAAAkD0/vb1Cu5jTzak/s800/upload_-1.jpg)
(https://lh4.googleusercontent.com/-vGURRs-8VWw/VP9V3YNHjOI/AAAAAAAAkD8/zgUZAcyQF6s/s800/upload_-1.jpg)
All done, it should sit flush with the yolk housing
(https://lh3.googleusercontent.com/-LqXGNGa90bY/VP9V5GGThqI/AAAAAAAAkEE/eWR-m67BV70/s800/upload_-1.jpg)
feed and lay the cable underneath the black ring, and fit the moulding to the ring so the cable exits correctly
(https://lh6.googleusercontent.com/-ET8WN0xIxZc/VP9V6yZX3vI/AAAAAAAAkEM/N2v4tMDSy1Y/s800/upload_-1.jpg)
refit the yolk to the ball
(https://lh3.googleusercontent.com/-2kPq58S65x4/VP9V8mk1TXI/AAAAAAAAkEU/DKH8LymSQns/s800/upload_-1.jpg)
Onto the chassis now. Reassemble the suction diverter assembly
(https://lh6.googleusercontent.com/-sfBFVlVKRXM/VP9V-5JPxJI/AAAAAAAAkEc/jNe3mDMtKBg/s800/upload_-1.jpg)
fit the [attach=1] to the housing
(https://lh4.googleusercontent.com/-M-3t7Rx7tFQ/VP9WAc4nKpI/AAAAAAAAkEk/IoQ_723YmUc/s800/upload_-1.jpg)
then the hose to the housing
(https://lh3.googleusercontent.com/-iFh4ynGVA8o/VP9WBoO9uwI/AAAAAAAAkEs/EwrC8hXV8GI/s512/upload_-1.jpg)
Then from underneath the housing to the chassis, making sure the 3 pegs locate correctly
(https://lh4.googleusercontent.com/-lwDi5IjBGlE/VP9WDedjWnI/AAAAAAAAkE0/geYDMG9sGXo/s512/upload_-1.jpg)
Fit the changeover valve [attach=1]
(https://lh6.googleusercontent.com/-2-6vmJcYN08/VP9WE6UPOjI/AAAAAAAAkE8/3SxL-aguAqg/s800/upload_-1.jpg)
Snap the flap onto the housing, hold the spring onto it then push the locating peg in to hold it all in there
(https://lh4.googleusercontent.com/-oC8npPBE3M0/VP9WGl2-jzI/AAAAAAAAkFE/-ogutYDg9OU/s800/upload_-1.jpg)
screw it in from the back
(https://lh5.googleusercontent.com/-xEQPtahWiVc/VP9WIVeM2OI/AAAAAAAAkFM/PLkQ-EeAJ90/s800/upload_-1.jpg)
refit the spring and clear nipple
(https://lh3.googleusercontent.com/-LuU1_tflPVg/VP9WJ1n8DtI/AAAAAAAAkFU/cjp8YEQ_tL8/s800/upload_-1.jpg)
Fit the below spring onto the below peg, as per the orientation shown
(https://lh5.googleusercontent.com/-yH7e0J5xPQY/VP9WLcoYS5I/AAAAAAAAkFc/a7vs05Oy9-c/s800/upload_-1.jpg)
slide the side of the changeover assembly onto the valve, then screw the changeover valve onto the bottom of the chassis
(https://lh6.googleusercontent.com/-gJYTyl6exZc/VP9WNIYW8nI/AAAAAAAAkFk/Ng4zZDLWWqY/s512/upload_-1.jpg)
refit the changeover wheel
(https://lh6.googleusercontent.com/-FTpYevn6yFM/VP9WPMPWJ9I/AAAAAAAAkFs/pUkAfds932o/s800/upload_-1.jpg)
(https://lh4.googleusercontent.com/-7MEO4Xku1GM/VP9WQpyOsxI/AAAAAAAAkF0/NkiEAf1q_os/s800/upload_-1.jpg)
fit the ball tension peg and spring as shown
(https://lh5.googleusercontent.com/-YJ-L8tRjK98/VP9WSbwM_vI/AAAAAAAAkF8/Q1gDM2SzqiI/s800/upload_-1.jpg)
fit the grey pedal into the chassis
(https://lh3.googleusercontent.com/-XAWlThMP168/VP9WT-O0Z0I/AAAAAAAAkGE/NdcCss7iLEY/s800/upload_-1.jpg)
(https://lh5.googleusercontent.com/-mxamAbc0E8I/VP9WVsu74SI/AAAAAAAAkGM/nL6dvDOO8v4/s800/upload_-1.jpg)
(https://lh5.googleusercontent.com/-uJzsL_cON98/VP9WXOVhaSI/AAAAAAAAkGU/nvTDK0CROmk/s800/upload_-1.jpg)
feed the spine wire up the chassis and locate the wires back into their chases
(https://lh6.googleusercontent.com/-t4g5jr3JptY/VP9WY0tXlmI/AAAAAAAAkGc/knbkFY73gNA/s800/upload_-1.jpg)
insert the red pedal in
(https://lh6.googleusercontent.com/-VsH_sozlEXE/VP9Wat1EUUI/AAAAAAAAkGk/zD1_MMi3KiA/s800/upload_-1.jpg)
fit the loose pring onto the grey pedal, and check the red one bounces off the nipple correctly ( :underchair:)
(https://lh5.googleusercontent.com/-2mEc-H1Oyho/VP9WcJd9plI/AAAAAAAAkGs/pqJ-iqz55q8/s800/upload_-1.jpg)
refit the [attach=1] to the motor housing
(https://lh4.googleusercontent.com/-G9a2RZU1SoM/VP9Wd-yZukI/AAAAAAAAkG0/27tShGctg2E/s800/upload_-1.jpg)
and refit the ball and yolk to the chassis. Secure it with the ball screws on either side
(https://lh3.googleusercontent.com/-5ek3Z6Yr2Kk/VP9WfvjBS8I/AAAAAAAAkG8/PjwqOEu_euc/s800/upload_-1.jpg)
connect all the wires back up, and refit the mictoswitch and housing
(https://lh4.googleusercontent.com/-_FSLUxSD4n8/VP9WhIzoAhI/AAAAAAAAkHE/2Foxbt0d4cg/s800/upload_-1.jpg)
pop up top and re-wire the switches in and tidy up all the cables
(https://lh3.googleusercontent.com/-sXWtcZzQEDY/VP9WigPdEGI/AAAAAAAAkHM/yG26bAFGw1Y/s800/upload_-1.jpg)
refit the switches and switch housing
(https://lh4.googleusercontent.com/-KMemteHDdgU/VP9Wkcj_1dI/AAAAAAAAkHU/39kcqpEMPqQ/s512/upload_-1.jpg)
I opened a new post motor filter
(https://lh5.googleusercontent.com/-uUr0sS1wUbY/VP9WmA-Va_I/AAAAAAAAkNk/mUGaZYI8lUY/s512/upload_-1.jpg)
bit cleaner
(https://lh4.googleusercontent.com/-DzB1NwzykL0/VP9WnpAqV6I/AAAAAAAAkHk/1ov3B-mAqZA/s800/upload_-1.jpg)
and fitted it.
I then opened some post from manchestervacs, and withdrew a new cyclone seal!
(https://lh6.googleusercontent.com/-jbrYaKiKBxU/VP9WpHYizJI/AAAAAAAAkHs/spaNN9705po/s800/upload_-1.jpg)
(https://lh6.googleusercontent.com/-nMM9vs9b1xc/VP9Wq5QbyGI/AAAAAAAAkNs/Ou8h3NtbaD8/s800/upload_-1.jpg)
which meant I could finish the cyclone off! The pre motor filter washed up very well
(https://lh4.googleusercontent.com/-JlARj-iz3hg/VP9WucXnMEI/AAAAAAAAkIE/-2FuBQqX4jA/s800/upload_-1.jpg)
I gave the brushroll pcb to someone who needed one, so mvacs kindly sent me another one!
(https://lh6.googleusercontent.com/-d1G3GzGXLpQ/VP9WwAX2moI/AAAAAAAAkIM/lswxD5c5BoA/s800/upload_-1.jpg)
so that night I started on the brushroll housing
initial connector back together and fitted
(https://lh4.googleusercontent.com/-J1pwNsyfoLc/VP9WyGDwt8I/AAAAAAAAkIU/-W_DAH-Vx9w/s800/upload_-1.jpg)
refitted the motor
(https://lh5.googleusercontent.com/-D2Y_o5aHa-c/VP9WzzEylpI/AAAAAAAAkIc/4cbA_cmJSxU/s800/upload_-1.jpg)
(https://lh5.googleusercontent.com/-tX0H49C-9KM/VP9W2B5BwZI/AAAAAAAAkIk/0zewIbkPwgs/s800/upload_-1.jpg)
lowered the clear housing on
(https://lh3.googleusercontent.com/-EOH7AhQ4FZQ/VP9W4E5DwvI/AAAAAAAAkIs/PUstasOfxTA/s800/upload_-1.jpg)
fitted the motor cables into their slots
(https://lh5.googleusercontent.com/-aFwqgry7HQU/VP9W6Hh9qAI/AAAAAAAAkI0/4o_5As6tnWg/s800/upload_-1.jpg)
fitted the pcb, not forgetting the reset switch surround
(https://lh4.googleusercontent.com/-o86JElkQ2Po/VP9W8Mm0MkI/AAAAAAAAkI8/Fp1Fz7TIOXs/s800/upload_-1.jpg)
plugged the motor in, then turned it upside down and fitted the sole plate on
the squeegee was fitted, brushroll and end cap on and the brushroll was fitted to the machine. Hose and wand were put back on and...
(https://lh4.googleusercontent.com/--LfnadCcDMY/VP9XAfj7D5I/AAAAAAAAkJM/fJQftsCpMm0/s512/upload_-1.jpg)
(https://lh3.googleusercontent.com/-VvJ4MD4POLc/VP9XCQD2pMI/AAAAAAAAkJU/Wjv4fHBrAr0/s512/upload_-1.jpg)
(https://lh5.googleusercontent.com/-lKCupYQOgxc/VP9XEk-7_nI/AAAAAAAAkJc/n3yEH8UZics/s512/upload_-1.jpg)
(https://lh5.googleusercontent.com/-kb99SDwnkLQ/VP9XGDW9zRI/AAAAAAAAkJk/A1KreeD22fc/s800/upload_-1.jpg)
(https://lh4.googleusercontent.com/-ajISACeuqms/VP9XINoMP6I/AAAAAAAAkJs/gYvUca_OtCI/s800/upload_-1.jpg)
(https://lh6.googleusercontent.com/-JJo45fDTbi4/VP9XLgDUjyI/AAAAAAAAkJ8/jNW6nroISQw/s800/upload_-1.jpg)
(https://lh3.googleusercontent.com/-PZjHDZgoduc/VP9XNRCGBfI/AAAAAAAAkKE/80XJR_YceV0/s512/upload_-1.jpg)
(https://lh5.googleusercontent.com/-LF4ITrhGdIQ/VP9XSxyypuI/AAAAAAAAkKc/ig2af3VAUkU/s512/upload_-1.jpg)
and she's done! Hope this helps anyone looking for an answer to any of the DC24's many, many problems!
Thank you for the stripdown and the pics.
I'm having trouble with my DC24: its diverter valve won't stay in base mode. I don't really see how the mode is activated, I can manually turn the clear wheel in both positions and the air ducts are free (suction in both positions is ok), but the valve always springs back to hose mode. Maybe my wheel is overturned?
Can you tell from your model, how the wheel is operated, when switching the Dyson from hose to base mode?
Yours,
Ray
The changeover valve is operated by the clear wheel and a pivot arm.
With the wand in place, the wand pushes the flap down, which pushes the lever around, turnig the clear disc and moving tbe little hose to the left as you look at the machine.
Is the assembly on the left in tact? Should be 2 locating lugs, and a further lug that moves around the cutouts in the chassis. You should be able to manipulate it by hand with the wand and cyclone off to check operation.
The assembly is ok, I can move the clear wheel and the little hose switches position. I will check for what the wand does to the wheel when I get back home. Thanks for the fast answer!
Stupid me :'(
I was checking the diverter valve when reassembling the Dyson after I cleant the two little air hoses on the side of the base (the one from the diverter and the one below on the way to the base). AND I SIMPLY CHECKED THE DIVERTER VALVE WITHOUT PUTTING THE WAND BACK IN PLACE!. I was completely unaware of the wand actually "operating" the clear wheel.
A big THANK YOU :bow: to this forum ... and beko in particular for the fast response and guiding me to the "magic" wand.
I was all set and ready to send the vacuum in to Dyson Germany.
Cheers,
Ray
No worries, glad you got it fixed. Just remember to turn the brushroll off when not vacuuming carpets and she wont go pop too soon!
Another thanks for this tear down and rebuild.
I have got a dc24 for literally a couple of quid and I want to tear it down as its filthy and needs its dead brush bar remedying.
Very much appreciated.
Excellent, all the best with it! Their silly cheap if your willing to put the work in!
Does the reset button need pressing on the brushroll housing? If that doesnt fire it into life then try a PCB
I have tried that but no dice sadly.
They are a little more involved than the DC07's but I have repaired a DC27 so I think I can take the next step!
Will take a multi meter to the pcb and see if it is giving out any juice, would rather the motor is dead as they are cheaper ;D
Knowing the 24 it could be both!
Their not too bad, just fiddly. The rear wheels, red pedal and associated springs are the fiddly bits, as is the spring that sits under the middle red part of the cyclone release, it has to go in a very specific way always takes me a few attempts, sadly you have to reassemble the cyclone ever time to check!
Forgot to say, I had a dc24 the other week with no reset button on the brush bar just blanked off, when did that happen?
Late model! Happened in 2012/2013 I believe, the brush motor should be spinning slightly slower too and the head clip is red
Top beardage Tayyab!
:)) ;D
Correct
Hi, you seem to know your stuff on these machines - wonder if you can help. I've just bought a used dc24. It worked well for a few days, then when vacuuming the rug the brush bar stopped. I tried pushing the reset but no good. Taking the head apart I get 240vac coming onto the pcb but no voltage on the output to the motor. I've checked the reset switch, but the 2 contacts seem to be open circuit all the time, even when the button is depressed. Should these go closed circuit, or should they be normally closed and go open when the button's pushed? I have been told if the pcb his faulty then the motor is too probably. Is there any way I can check this?
I'd be grateful for any info you might have.
