Dyson Models => Dyson DC07 => Topic started by: quick978 on December 04, 2016, 10:34:28 pm
Hi guys,
I'm quite new to the game and needed some advice.
I've just serviced a DC07 and the suck from the pipe is very strong, but from the floor it is so weak, I have taken the bin off and checked where the bottom vent goes into the bin and it is strong, I have checked the hose underneath and it is intact with no splits, if I wasn't as bald as a coot I would be pulling my hair out!!!
Does anybody have a solution?
Did you check the side diverter valve pipe? Sometimes they do not fully engage when you recline the machine. Also would be a good idea to check the seals. Hope this helps.
hi if done above I would change the flexi hose just because it has no spits don't mean its there I have had them look good or just twist it if you have had it off if not just change they are cheap
